Have to Replace the Front Wheel Hub
Old Dec 4, 2012 | 04:47 AM
Thmprr's Avatar
Thmprr
Default Have to Replace the Front Wheel Hub
Had a vehicle inspection today on the 2006 C6, they say the RH front front wheel bearings are exhibiting too much vibration and noise whilst turning.
I have ordered the replacement hub, I can see that the brake caliper has to come off, brake rotor, and the bottom ball joint so the Torx screw can be accessed.
What are the torque figures for the brake caliper, wheel hub Torx screws and ball joint?
Old Dec 4, 2012 | 05:21 AM
taken19's Avatar
taken19
Track Junky
Lower ball joint is 20 ft-lbs, then 180 degrees
Wheel hub torx is 96 ft-lbs
Caliper bolt is 125 ft-lbs
Old Dec 4, 2012 | 05:56 AM
timd38's Avatar
timd38
Getting those torx fastenors out is a real challange. My car had 8K miles on it, never been in salt or snow and it wat a real b$tch to get them out.
You may ask why I replaced at 8K, I installed the SKF performance hubs.
Old Dec 4, 2012 | 05:40 PM
dbratten's Avatar
dbratten
I've found it easier to go the extra steps of removing the joints for the steering and upper ball to take the spindle off the car -- whether front or rear -- to change hubs. Get it out in the open where you can easily get a big breaker bar or impact wrench on the hub bolts and even place the spindle in a vise, if necessary. The extra couple of minutes to remove and replace these joints will save a lot of cursing.
--Dan
Old Dec 4, 2012 | 06:28 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
I took the spindle off the car, did both the rears, so i had the joy of fighting with the half shafts as well.
took me about 5 hours for both sides.
-Carl
Old Dec 7, 2012 | 03:59 AM
Thmprr's Avatar
Thmprr
Thanks, all done and back together. Did not need to remove the upright, job took about 2hrs.
I'm still mystified as to why only one side failed, must have been a faulty bearing.
To Have to Replace the Front Wheel Hub
