Bolton LS2 dyno
Old Dec 7, 2012 | 10:52 AM
WildVettes's Avatar
0WildVettes
Former Vendor
St. Jude Donor '12
Originally Posted by COHPARTS
if you look at the pic of the computer monitor youll see the correction factor is set to std (standard) instead of s.a.e. So thats why its a lil higher than normal.
Yeah if those aren't SAE corrected it could read higher or lower. The air was so good on my dyno day the car read almost 450 rwhp before it was SAE corrected.
Old Dec 7, 2012 | 11:29 AM
Shoaf85's Avatar
Shoaf85
Take it to the track and u'll know
Old Dec 8, 2012 | 01:25 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
OP, LMR can change your dyno runs to SAE corrected and email you the updated dyno runs. Might be interesting to see what your true numbers are?
Old Dec 9, 2012 | 02:27 PM
STROKD's Avatar
STROKD
Prob right at 390/392ish... Its about a 10 hp/tq bump. My local shop uses STD too and I ALWAYS change it, so Im getting used to the drop due to the correction factor from STD-SAE.
Old Dec 9, 2012 | 11:14 PM
c6vette142dude's Avatar
c6vette142dude
Originally Posted by C U IN REARVEIW
stock tb/intake?
Originally Posted by Underratedneverfaded
Yes they are stock but are my next mods
No need if you plan to get a blower next.
Old Dec 10, 2012 | 12:23 AM
J Christensen's Avatar
J Christensen
Finally got a chance to put the old vett on the dyno during LMR'S dyno day. The current mods are corsa sports,vararam intake,kooks off-road longtubes,160 thermo, and a mild street tune. I was very pleased with the results.
What were your base/stock numbrers?
Old Dec 10, 2012 | 12:29 AM
J Christensen
Originally Posted by camirocz
Wjhat important is not what you dyno but how much gains you acheived adding your mods.Every dyno doesnt read the same but gains are gains.
I agree. Knowing your base setup is a good help, and use the same dyno as you go along, or use the same model, certified dyno if at different locations. I've had pretty good cross reliability with different dyno's given the above - usually within .5 hp or so.
