Help
Old Dec 14, 2012 | 06:02 PM
bucwheat's Avatar
bucwheat
Default Help
Hey guys I bought a power tap also called invisacord for my Escort 8500,you can't swivel the mirror around enough to plug the two wires in so I'm thinking just unplug the power supply and install that way,OK how da hell do you get the plug to release?
Old Dec 14, 2012 | 06:47 PM
timd38's Avatar
timd38
Push down on the locking tab.
Old Dec 14, 2012 | 08:23 PM
bucwheat's Avatar
bucwheat
I can feel the tab at the top give a little with pressure,but it won't release,I have a tendency to brake things easily. So I wasn't sure if there were more than one tab,thanks.
Old Dec 15, 2012 | 06:16 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
There is only the top tab. The trick is to get a straight pull out while holding the tab down.
Old Dec 16, 2012 | 12:33 PM
Cherokee Nation's Avatar
Cherokee Nation
No need to unplug the connector.I used a the tool that doctors use( Don't know what they are called) I call them Roach holders.Turn the mirror to the right & use that tool to push the wires into the pink & black wires.Very easy...
To Help
