Clicking issue?
Old Dec 15, 2012 | 01:58 PM
SiKc6's Avatar
SiKc6
Default Clicking issue?
What's up guys I have a question.
I have researched a lot about this but still can't figure it out. I have a 2007 z51 m6 and when I accelerate I get a strange "clicking" noise from the rear of my car. It is t the clutch because when I completely come off of it and just start to give it gas it makes this noise. I have 48,000 miles on this car. I don't have a warranty so I'm not really wanting to take it in to the dealer and pay hundreds of dollars for them to look at it and just tell me they don't know what it is? Has anyone had this problem? What did u find? I am located in northwest houston if it matters. Any help would be appreciated thanks!
Old Dec 15, 2012 | 02:40 PM
EVRose's Avatar
EVRose
Possible loose axle nut.
Old Dec 15, 2012 | 05:36 PM
SiKc6's Avatar
SiKc6
Ok so I'm at work (train mechanic) checked both axle nuts. Drivers side was to spec at 160. Passenger side was around 85. Torqued it down. Well see if the noise is gone when I get off tonight. Otherwise I'm at a loss?
Old Dec 15, 2012 | 05:48 PM
Z11409's Avatar
Z11409
#PIC4475B
#07-04-20-002A
Subject: Tapping or Scraping Noise From Rear Wheel Area (Replace Wheel Drive Shaft Nut) #07-04-95-001 - (09/26/2007)
Models: 2005-2008 Cadillac XLR
2005-2008 Chevrolet Corvette
Condition
Some customers may comment on a tapping or a scraping noise coming from the rear wheel area.
Cause
This condition may be due to the torque on the wheel drive shaft nut relaxing over time.
Correction
Replace the left and the right wheel drive shaft nut following the procedure below.
Remove the center cap from the rim.
Remove and discard the wheel drive shaft nut.
Apply LOCTITE™ 272, or equivalent, to the threads of the axle shaft.
Install the nut and tighten to the new specification.
Tighten
Tighten the nut to 215 N·m (160 lb ft).
Install the center cap to the rim.
Important: The vehicle should not be driven for 24 hours following the repair in order to allow the thread lock to cure.
Part Number
Description
Qty
10257766
Nut
2 (one per side)
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
F9712*
Wheel Drive Shaft Nut - Replace
0.3 hr
STAY OUT OF THE RED ZONE
Old Dec 17, 2012 | 04:27 AM
Wild's Avatar
Wild
Originally Posted by Z11409
# 07-04-95-001
#PIC4475B
#07-04-20-002A
Condition
Cause
Correction
Tighten
Part Number
Description
Qty
10257766
Nut
2 (one per side)
Labor Operation
Description
Labor Time
F9712*
0.3 hr
THANK YOU SOOOOOOO MUCH
To Clicking issue?
