In my 05 coupe my passenger sise mirror returns to the down and in position every time I turn the ignition off. Very frustrating. Anyone know what the problem is?
You need to set up the memory for your FOBs If you don't use the FOB to unlock the car and want to set the memory, just press MEM-1 or MEM-2 and it will set everything to your desired settings.
Do it the same for BOTH FOBs for now to make sure that the memory works . One you set the memory, it will stay where it suppose to be of go to that position when you use that FOB to unlock the car.
