Jacking pucks
Old Jan 3, 2013 | 08:18 PM
Gering's Avatar
Gering
Tolero Apto Victum
Originally Posted by victorf
I do like jacking pucks out of delrin - it is an designed bearing material, high strength and will not damage protective coating during contact. Eye bolt on hocky puck and even aluminum will damage the paint.
Here is my home made pucks out of delrin with a couple version for my unibody cars - not pretty but functional:
http://i896.photobucket.com/albums/a...ps767dec1f.jpg
They look very good.
Old Feb 26, 2013 | 10:22 PM
92PGC's Avatar
92PGC
what size eye bolts work best 3/8 or 1/2 ?
thanks
Old Feb 27, 2013 | 06:02 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Originally Posted by EVL JAKE
Because a good amount of people believe you simply can not jack up a Corvette with out jacking pucks. It's an ingenious marketing ploy, I just find it amusing.
Have to agree. I installed the BMW pads years ago, lost one, now the side still with it is a pain in my rear as the car is too low to get the jack under the side with the pad. I'm about ready to take it out. I've jacked the car up hundreds of times with no pad and never damaged anything. Heck I don't even have to get under the car to check placement of the jack any more, I know where to put the jack.
Looking back at my old post above, seems I stopped being so careful!
Old Feb 28, 2013 | 02:27 PM
victorf's Avatar
victorf
Thanks.
I am sure with your well cared for and professionally prepped performance DD, you are aware the exposure to lots of "normal" airborne under carriage projectiles in your travels.
On that note, I do what I can to lessen the intentional or inadvertent mishaps during normal maintenance.
Old Feb 28, 2013 | 04:03 PM
JCtx's Avatar
JCtx
Jacking pucks are a must, especially if you use a jack, since as car is lifted (angled compared to the flat cradle), all the weight will be at one spot. The pucks distribute the weight evenly at a much larger area. Common sense, right? .
Anyway, I have 4 round BMW pucks 'permanently' installed. But also bought one of the taller, rectangular ones to use with the BMW jack kit I carry on trips, to be able to patch a flat (even runflats crap out at 50 miles tops if not plugged). And yes, I carry a plastic trim tool to easily remove any of those pucks. Pics of both below. A wise investment IMO, since they'd never come off on their own. By the way, remove the middle pin from the rectangular pucks, to avoid locking them in place accidentally (those are too tall to leave installed all the time). Hope this helps.
Old Feb 28, 2013 | 04:06 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
^^^ I actually hit something in the road and lost one of my BMW pucks like that.
Frankly I don't use the puck on that side anymore and my car is no worse for wear. I am no longer a fan of the pucks as they cause me to need to drive on boards to jack the car.
Old Feb 28, 2013 | 05:29 PM
brodyscorvette's Avatar
brodyscorvette
Originally Posted by ptroxx
5.00 for a set of 5 used pucks from ebay and a few eye bolts from HD and your good...
and yes you can use the crossmembers
That's the route I went, jack still fits under them and they conform to the jack-stands well...
