Jacking pucks
Old Dec 27, 2012 | 11:44 AM
refewster's Avatar
refewster
Cruising
Default Jacking pucks
Just received the set of jacking pucks for my 13 coupe. Has anyone used them and are there easy to identify holes in the frame to insert them into and do you leave them installed? Thanks for any help or guidance. Happy new year to the forum family.
Old Dec 27, 2012 | 12:15 PM
Mike's LS3's Avatar
Mike's LS3
Yes, I use them anytime I lift my car. I keep two in my car at all times and have given them to the tire shop to use.
The frame holes are located about 22" behind the front tires and 24" in front of the rear tires and easy to identify. I have the hard rubber hockey puck type with an "eye" bolt screwed in and epoxied to the puck. I push in and twist them on only when I need to raise the car. I do not leave them in, but they will stay in on their own. Hope that helps!
Old Dec 27, 2012 | 01:31 PM
carpe dm's Avatar
carpe dm
I made some from used hockey pucks, and use them regularly. I do not leave them installed. I also so carry a set in the rear compartment in case I need them when travelling.
Old Dec 27, 2012 | 01:33 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I have them only on the front jacking points and leave them in all the time.
You can jack up the entire side of the car using the front points...that's how I swap tires for racing, one side at a time.
Old Dec 27, 2012 | 03:18 PM
EVL JAKE's Avatar
EVL JAKE
St. Jude Donor '12-'13
Jacking pucks are the biggest farse in the Corvette community, it's funny how many people buy them.
Old Dec 27, 2012 | 03:39 PM
MarkDFW's Avatar
MarkDFW
I jack the side of the car using the rear jacking points to swap tires on each side for the track. Either side should work. I don't leave them in, just put them in the cubby holes in back.
Old Dec 27, 2012 | 04:00 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
One of mine fell out and I lost it (I have the BMW factory jack pads you can get from the BMW dealer), one of mine is still in there. Because of that I noticed something.
They are useful in that when the pucks are in, it's easy to locate the jack under the car.
With no puck, you have to be very careful to not catch the jack pad on the front fender or the rocker panel, you will crack them if you get the jack pad on them.
That right there is why I think they are useful.
Old Dec 27, 2012 | 04:02 PM
MarkDFW's Avatar
MarkDFW
Old Dec 27, 2012 | 04:08 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I use the front, as the front is heavier so in my mind I'm tweaking the frame less. Of course our cars are nearly 50/50 so I bet it doesn't really matter!
I went years using the rear cradle then the front cradle, which is a pain as my jack doesn't fit under the front without using boards. The side jacking trick is a real time saver for me.
Old Dec 27, 2012 | 04:12 PM
MarkDFW's Avatar
MarkDFW
All I'm doing is swapping wheels/tires for the track and maybe brake pads. I have a local shop that does the rest. Jacking from the side is all I ever plan on doing.
Old Dec 27, 2012 | 04:18 PM
mourat's Avatar
mourat
Dont leave them in there, the aluminum ones stay better, the Eye ones with rubber pucks can fly off.
I left mine on, went for a drive, went over some bumps on the road and sure enough heard them fly off, got home, just had the front ones on. Ordered another cheap set on ebay.
Old Dec 27, 2012 | 04:46 PM
EVL JAKE's Avatar
EVL JAKE
I've always used the front and rear cross member since the tires can't be rotated. Never had a use for the pucks.
Old Dec 27, 2012 | 05:06 PM
Devilish34's Avatar
Devilish34
I use hockey pucks
Old Dec 27, 2012 | 05:18 PM
Mike's LS3's Avatar
Mike's LS3
I bet those who cracked their rocker panel wish they did!
Old Dec 28, 2012 | 08:10 AM
RoadkingC6's Avatar
RoadkingC6
Why do you say that ?
Old Dec 28, 2012 | 08:22 AM
EVL JAKE's Avatar
EVL JAKE
Because a good amount of people believe you simply can not jack up a Corvette with out jacking pucks. It's an ingenious marketing ploy, I just find it amusing.
Old Dec 28, 2012 | 08:44 AM
Flame Red's Avatar
Flame Red
If you want to install them permanently, put a dab of silicone on the puck and they will never come off while driving.
To Jacking pucks
Old Jan 2, 2013 | 11:47 PM
Gering's Avatar
Gering
Tolero Apto Victum
Here is a picture of one of my jacking pucks.
Old Jan 3, 2013 | 12:00 AM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
5.00 for a set of 5 used pucks from ebay and a few eye bolts from HD and your good...
and yes you can use the crossmembers
Old Jan 3, 2013 | 01:14 PM
victorf's Avatar
victorf
I do like jacking pucks out of delrin - it is an designed bearing material, high strength and will not damage protective coating during contact. Eye bolt on hocky puck and even aluminum will damage the paint.
Here is my home made pucks out of delrin with a couple version for my unibody cars - not pretty but functional:
http://i896.photobucket.com/albums/a...ps767dec1f.jpg
