tranny problem
Old Jan 1, 2013 | 02:13 AM
clayz's Avatar
clayz
Default tranny problem
Have a problem with my 2007 a6 . I can paddle shift the car to 3rd gear but when I shift to 4th a x appears in the hud . If I take of in regular drive when it gets to 4th the check engine light comes on and throws a code p0796 . Have to clear the code then start pedal shifting again !!!!! Any suggestion
Old Jan 1, 2013 | 03:07 AM
Richard Fitzwell's Avatar
Richard Fitzwell
Account Suspended by request 15 Sept 2016
Torque converter TSB 4302.
Old Jan 1, 2013 | 08:05 PM
RicK T's Avatar
RicK T
Looks like the symptoms fit this PI:
#PIP4184B: MIL And Any Combination of DTC P0756 P0776 P0796 P2714 P2723 - keywords intermittent ses - (Dec 20, 2007)
Subject: MIL And Any Combination of DTC P0756, P0776, P0796, P2714, P2723
Models: 2006-2008 Cadillac XLR-V, STS-V
2008 Cadillac CTS
2007-2008 Cadillac Escalade, Escalade ESV, Escalade EXT, SRX, STS, XLR
2006-2008 Chevrolet Corvette
2007-2008 Chevrolet Silverado
2007-2008 GMC Sierra, Yukon Denali, Yukon Denali XL
2008 Hummer H2
Equipped With 6L50, 6L80 or 6L90 (RPOs MYB, MYC, MYD) Automatic Transmission
This PI Supersedes To Add Models. Please Discard PIP4184A.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may comment on a transmission concern where the MIL is illuminated and any of the above listed DTCs may be found in the TCM as active or history codes.
Recommendation/Instructions:
Perform the following service procedures:
Record Freeze Frame / Failure Data for all DTCs. This can be done electronically with the Tech 2 by capturing the data or by manually writing down the parameters. This data may be requested by TAC if further assistance is needed.
Check and note the transmission fluid level and condition. If the level is high or low it should be corrected and the vehicle road tested to verify that the condition is still present.
Remove the transmission bottom pan to inspect for possible debris. If debris is found the transmission should be disassembled to determine the source. Repair or replace the transmission in the most economical method following guidelines in the latest version of bulletin 02-07-30-029.
If no debris is noted in the oil pan remove the valve body / control solenoid and module assembly. Disassemble the valve body to: Inspect the check ***** for roundness ensuring that there are no flat spots. Inspect the spacer plate for debris, burrs or flashing on the orifices. Measure all the valve body bore plug (328) diameters. Specification = 11.502 mm +/- 0.004 mm. Undersize bore plugs should be replaced. Inspect all valves for freedom of movement and correct travel.
Based on the specific DTC carefully inspect the following valves for freedom of movement and correct travel.
P0756 - Clutch select valve 3 (352) (closer to the manual valve) in the lower valve body (307).
P0776 - 3-5-R clutch regulator valve (336) in the upper valve body (321).
P0796 - CBR1/4-5-6 clutch regulator valve (327) in the upper valve body (321).
P2714 - 2-6 clutch regulator valve (334) in the upper valve body (321).
P2723 - 1-2-3-4 clutch regulator valve (337) in the upper valve body (321).`
• If a concern is found in the respective valve line-up remove the valve from the valve body.
• Once valve is removed inspect for any scratching or scoring.
• If any is found then the fingernail test will need to be performed.
• Using your fingernail to move over scratches to see if nail will try to catch on the scratch or score.
• If so then valve body will need to be replaced.
• It has been found that in most cases that the scratches are not severe enough to catch your fingernail.
• In this case the valve should be cleaned with some type of contact or brake cleaner.
• The bore should also be cleaned. Clean with machined side down so debris may escape.
• Blow off with shop air.
• To verify free movement of the valve, dip into clean ATF and install valve back into the bore, the valve should move freely. If the valve moves freely, in most cases the valve body will function properly when reinstalled.
• Reassemble and retest.
If no issues are noted in the valve body inspection replace the control solenoid and module assembly (314). If the concern was a DTC P2723 the input / output speed sensor assembly (303) should also be replaced.
Old Jan 1, 2013 | 08:44 PM
clayz's Avatar
clayz
2008 Cadillac CTS
2008 Hummer H2
Condition/Concern:
Thanks bro real good info right their !!!!!!
To tranny problem
