I am sure it's been asked before but other than headers and a tune what can you do to an LS3 for $3K to get a worthwhile increase in performance. I already have headers and a tune.
hell, for an extra thousand you can buy a supercharger kit. i commonly see either complete supercharger kits on her for 4 thousand bucks, or incomplete kits that require you to source your own parts (piping/wastegates/bracket/etc) and end up totalling about 4 grand. I vote to save up and get charged up!
$3,000 will get a top of the line Nitrous Oxide system with all the bells and whistles and probably the install and tune also. Lots of companies to choose from, ask around your area for which is best.
I'm in the same boat as the OP... I have an 05 LS2 (A4) with a 2800 stall converter,KOOKS HEADERS, Vararam CAI, Cartek Tune, & Drag Radials..
I am ONLY a "BRACKET" Drag Racer.... the MOST IMPORTANT thing I need is CONSISTANCY... I only bracket race, or plan on running in an 11.5 "Index" class... as it is now my car is running 11.7x VERY CONSISTANTLY...I need to pick up about .3 or 4 tenths ....I KNOW a SC or Nitrous is a NO NO... it will lose consistancy...
I'm thinking my only choice is a cam.... I just ported the stock LS2 intake and have not made any runs with it, but maybe I'll be running 11.65 as it is now....
Is a cam my only choice, $3000 is also my MAX...oh & also I don't want to go to a 3600 converter because I'm using Nitto 555 (305/35x18") and my 60' times are 1.62 ... I don't think these tires will hold with more converter, & I DON'T want to have to use MT OR other $$$ Drag Radials because I have to drive 100 miles to the track & 100 back home.. & I'm getting great usage from these tires they are hooking with the 2800 converter, and I'm getting about 1 full year of racing with one set...
I'm thinking a cam is my only choice????
Have you considered a FAST intake? I bet that alone would get you .1-.2 consistently.
Gears will give you the most bang for under 3k installed, and no tune needed. You didn't say if you're going to install any of this yourself. If the 3k has to also cover install then your SOL on most of the above recommendations.
You could do a cam and intake with labor, but no way you can and a supercharger. I am not convinced that you can do a supercharger for $4k when you factor in all the stuff you don't know you need until you start the project.
Thanks guys... The FAST intake sounds good, but it alone costs about $1000...
& I still don't know how much of a gain I got from porting my stock intake manifold??
I'm thinking of making a few runs with the car as it is NOW.. & if I'm in the 11.6 - 11.65 zone, I'm going to need at least 3 tenths, 1. to make up for summer heat, 2. to prevent me from losing ET by "Deep Staging" (its a nessesity on a .500 Pro Tree) and 3. have a "little" in the bank if needed...
Oh I also plan on a MIZAIR electric water pump.. that should help me out a little freeing up some HP....
Thanks guys for your input. I want the car for street fun only. I agree that 4K won't get me a supercharger. I don't have the skill necessary to do the work myself. Around here its about 7K for a professionally installed SC. Maybe there isn't enough I could do for 3K to make it worth while. I'd do a SC for 4K but I know that's unrealistic. Thanks for your suggestions.
what about the LS3 MAF conversion?
Try some Roller rockers like 1.8 intake 1.7 exhaust Crane Quick lifts (this should help promote some nice torque increase)
do you have a ported TB?
you'll need some more "little things" like these since you mentioned the Meziere water pump
also could look at weight reduction, like Hotchkiss hollow sway bars, ZIPS light weight rotors, etc
again, sometimes the addition of little things add up, if you don't want to crack into the lower motor, convertor, gears
don't forget weather and temps will have an effect, as i'm sure you know since you want consistency
