Harmonic Balancer Replacement Question
ATI and Powerbond are 2 good choices.
I have not heard of any update to the balancer but if you trust your local shops that say there was a revision then I don't think it would hurt to do that.
In spite of what others claim, I have zero faith in GM parts that have a known history of above avg failure rates. It's a lot of work to R&R the pulley so it makes sense to me to just go with what is known to work well.
Since your car is out of warranty, why would you go with the oem pulley? PB or ATI is a better quality unit and IIRC both are available in oem sizes if you don't want to drop down a size.
Fact is, elastomer has an finite shelf life just sitting there, adding Corvette's torque to the equation and promises of longevity just evaporates.
In the end, most just rationalize with their decision, including myself with my ATI.
Hope this helps!!
Rich
Last edited by Allthrottleandsomebottle; Jan 6, 2013 at 06:26 PM. Reason: No non-supporting vendor self promotion.......
Hope this helps!!
Rich
Did GM use different material to join the inner and outer ring?
. Thx.
Pliable elastomer has well defined shelf life. When twisting torque is factored in, durability will become an issue. It is physically impossible to have longevity when steel parts is joined with an elastomer, with inner part fixed and outer parts exposed to twisting torque.
fact is, GM could change stock # and supplier but the nature of the beast remains.
My car has a twin disk clutch and combined with the heavy lope of the cam at ~650rpms, the noise was too much. I upped my idle to 900 and it has been perfect ever since.
I have ~13.8 volts at idle and a solid 14.1-14.3 any other time.
I assume those mentioned aftermarket units are not rubber-isolated, correct? Even if not a good design, GM spent extra on such a part for a reason, no? Otherwise they'd have fitted a solid unit themselves. The better question is what does a solid HB affects over time: main seals? Crank bearings? Hopefully the new design will last longer... and my car already has it
It is also an impossibility in toolmaking, to ensure the precision mold/die, to provide the elastomer bond, between the inner/outer ring will ended up with an concentric runout. Now, contrary to some, thinking their OEM damper runs true, compounding with the poor fit, with erratic runout of the OEM belt tension damper and what we ended up is an nightmare in the making.
OEM engine mount often fail too and fail miserably. I personally have changed my shock bushings to Delrin and when the time comes, other suspension cushion will also be Delrin.
ATI Damper is not solid, the unit is an assembly composed of many precision machined parts and it utilize "O" rings for cushion. It is rebuild-able and degree of damping can be control thru the use of different grade "O" rings. ATI is in a different league when compare with the more mundane after market varieties.
When choose to stick with the OEM design, most because concern with warranty, then, it is like sitting on an time bomb. Serious damage could happen if damper breaks, then warranty repairs. It like an fender bender, then get repairs - but the car will never be the same again.
This is another case of to each his own.
Good Luck with your OEM Damper.
. Guess I missed it then. Looks like we all will have to replace it in 7 years or so then. Oh well. Thanks man.
