Shift Light
Old Jan 20, 2013 | 04:12 PM
nvrpc's Avatar
nvrpc
Default Shift Light
Gone
Old Jan 20, 2013 | 07:23 PM
RicK T's Avatar
RicK T
Here's a prior discussion to get you started:
http://forums.corvetteforum.com/c6-t...ift-light.html
Old Jan 20, 2013 | 07:31 PM
BEZ06's Avatar
BEZ06
The Raptor is a very commonly used and popular shift light:
http://www.raptorperformance.com/Ins...e/corvette.htm
The single light might be good for drag racing, but for roadcourse use I like this one:
http://www.ecliptech.com.au/index.ph...=59&Itemid=109
I put that Ecliptech Shift-i progressive shift light in my Z06 and it worked great!!
I like seeing that I'm approaching the redline, instead of just getting a light when I get there.
You can set the lower light, and the upper light - so you can tell where you are in your power band.
Both of the above require you to tap into a tach wire for a signal.
Here's another very good solution that you just plug into the OBD2 port under the steering column:
http://dashtronix.com/Progressive_Shift.php
Dashtronix is a forum vendor, and the unit is designed to plug right into our Corvette OBD2 port, and you can select a couple different modes of display, and the info is displayed on either or both the HUD and DIC.
There's also a bright LED light you can run up to anywhere you want to mount it on the dash or over in a vent.
So.....those are a few possibilities.
Bob
To Shift Light
