Phadt featherlight question?
Old Jan 23, 2013 | 05:30 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Default Phadt featherlight question?
I bought a set of slightly used phadt featherlight coilovers...ive noticed that everyone else's pics of these c/o's the springs are black.....my fronts are blk but rears are red? Any insight on these,they were said to be factory stock....?
Old Jan 23, 2013 | 05:32 PM
articwhitec6's Avatar
articwhitec6
Call pfadt they built them they would know.
Old Jan 23, 2013 | 05:49 PM
C U IN REARVEIW
I know,just thought i'd try here first.....they work great....just curious
Old Jan 23, 2013 | 06:00 PM
jon6.0's Avatar
jon6.0
They might be an earlier generation.
Old Jan 23, 2013 | 06:24 PM
Homer3D's Avatar
Homer3D
Sounds like you might have custom rate springs if they are red like the ones that come with the "Double Adjustable" Featherlight Coilovers.
http://www.pfadtracing.com/catalog/p...roducts_id/235
Old Jan 23, 2013 | 08:19 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
the first run of the rear springs were red. same spring rate as the black ones.
Old Jan 23, 2013 | 08:32 PM
C U IN REARVEIW
These are the featherlights (circa) anodized orange tops,single adjustabillity,ect.....maybe just an earlier run and ended up with 2 red ones??
Old Jan 24, 2013 | 01:20 PM
Pfadt Racing's Avatar
Pfadt Racing
Hey man, what is the part number on the red springs? We customize spring kits for customers all the time, maybe this is one of them.
Look for the number that starts with 0800, and just read us the whole thing. I will be able to tell you what it is.
-Blair
Old Jan 25, 2013 | 11:06 AM
C U IN REARVEIW
-Blair
ok,great. won't be able to get car up in the air til this weekend though...will let you know. they guy i purchased from (forgot screen name) said he purchased them and drove a couple hundred miles on them,but were to rough even dialed down...so sold them to me.
Old Jan 25, 2013 | 07:21 PM
C U IN REARVEIW
-Blair
the #'s are...0800.225.0600
Old Jan 25, 2013 | 07:31 PM
jon6.0's Avatar
jon6.0
600lb Eibach springs.
http://www.summitracing.com/parts/eib-08002250600
Old Jan 25, 2013 | 09:13 PM
C U IN REARVEIW
Originally Posted by jon6.0
what is this particular spring designed for? autocross,dragstrip,ect?
Old Jan 25, 2013 | 09:33 PM
jon6.0's Avatar
jon6.0
I'm not familiar with the rates a C6 requires for each type of use. If the last owner felt they were too stiff, I would say they were built more track oriented. You could probably ask a question in the road race section and get a better answer. The cool thing about coilovers is you can change the springs to suit. Although if you make too big a change, the dampening circuits will need adjusted for the different spring weight as the range of adjustment will be outside the optimum dampening curve. I'm not sure if those Pfadts are rebuildable or revalveable. Hopefully Pfadt will chime in or call them Monday.
Old Jan 25, 2013 | 09:44 PM
C U IN REARVEIW
thanks ...i pm'd phadt and they cleared it up for me
Old Jan 25, 2013 | 09:56 PM
jon6.0's Avatar
jon6.0
What did they say the 600 pounders were good for?
Old Jan 25, 2013 | 10:01 PM
C U IN REARVEIW
he told me that they were the same rate as the normal ones. that when these were made they must have been out of the blk ones and ordered those from eibach to complete order...same spring just differant color thats all
Old Jan 25, 2013 | 10:05 PM
TMyers's Avatar
TMyers
600lbs is correct for the rears and 436 for the fronts if I remember right.
To Phadt featherlight question?
Old Jan 25, 2013 | 10:11 PM
C U IN REARVEIW
i would have thought the fronts would be stiffer due to weight?
Old Jan 25, 2013 | 10:17 PM
TMyers's Avatar
TMyers
Stock base/F55 springs are 420/657 and progressive. The Featherlights on the other hand are linear.
Old Jan 26, 2013 | 08:40 AM
C U IN REARVEIW
Oh ok,didnt think of it in that way....thanks
