Mod progress and problems
Old Jan 25, 2013 | 03:42 PM
Neil350's Avatar
Neil350
St. Jude Donor '12
Default Mod progress and problems
I bought the car back in 2011, it's an 07 M6, the mods it had were a Callaway Cold Air and a Borla. The car made 36xRWHP/36xRWTQ, I can't recall the exact numbers but I remember the torque and HP being the same number which was kind of funny. The last round of mods I did Stainless Works Long Tubes, Stainless works X and their high flow cats, the car also got fresh plugs and MSD wires. This yielded 373rwhp/390rwtq on a different dyno, then it got a tune and the car made 383rwhp/399rwtq. I figure these are right in line given the stock LS2 Manifold, Stock throttle Body and pulley. One thing I noticed after the tune, the car is a lot more responsive, it's really fun to drive.
The only bad thing is I had been hearing a squeak, I figured it was just when the car was cold but it turns out the squeak was the harmonic balancer wobbling, which turns out seems to be fairly common given what I have read on here.
Old Jan 26, 2013 | 12:10 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
It is now time to replace the balancer with a Powerbond unit or an ATI, might want to consider having a cam installed as they are over half way there by the time they get to the factory balancer. Even if you chose to not do the cam, install a 10% under driven balancer either way.
Old Jan 26, 2013 | 01:13 PM
Neil350's Avatar
Neil350
St. Jude Donor '12
The Powerbond seems to have good reviews, I am not sure about doing the under drive. I like to keep it using the stock size belt for simplicity, my 93 has an ATI that is the stock diameter. Cam's a tough choice, I don't want to give any drive ability since the car is so fun as is.
Old Jan 26, 2013 | 02:36 PM
DSOMC6's Avatar
DSOMC6
I've been running a PB on my turbo C6 for a couple yrs now. Good product for the $$.
Adding the right cam wouldn't sacrifice much drivability. But it would add to the cost somewhat to do it right. At a minimum I would add dual valve springs/titanium retainers, hardened pushrods. And personally I would spend the extra $300 to upgrade to Katechs high flow oil pump and C5R timing chain since you are already in there. Throw in a couple hundy for min tune/dyno time and you are easily over $1k depending on who grinds/sells the cam.
Old Jan 26, 2013 | 02:49 PM
jon6.0's Avatar
jon6.0
Depending on the lobes and lift he may only need a good single spring. Ed Curtis of Flowtech Inductions can spec you a cam to meet all your needs and pick up power all across the rpm range. I would do the Comp Cams trunion upgrade on your factory rockers while you are at it.
Old Jan 26, 2013 | 11:25 PM
Neil350's Avatar
Neil350
St. Jude Donor '12
I think I found the correct part number PB1117-SS , seems to be the correct balancer in the stock size. I will call SDPC and order it on Monday, I have looked more and more at cams. I see a lot of similarities between all the different vendors, just the names changes.
Old Apr 29, 2013 | 11:02 AM
Neil350's Avatar
Neil350
St. Jude Donor '12
To update, ended up going with the Power Bond in the stock size with an SDPC bolt, so wobbly balancer issue fixed. Also did a cam, TSP 228R on a 114 with their dual valve spring kit. Car made 432RWHP and drives like it did stock far as manners, only at idle can you tell it has a slight chop to it. Feels really good for what it is and the car picked up a decent bit of power from the cam swap. It'll stay as is for a while, this summer if I am off I plan to drive the car to Bowling green to watch the LTX shoot out and revisit the Corvette museum.
Old Apr 29, 2013 | 11:51 AM
All2Easy's Avatar
All2Easy
Well done and congrats on the new found power!
Old Apr 30, 2013 | 04:14 AM
Neil350's Avatar
Neil350
St. Jude Donor '12
Thanks man. I may look at putting a blower on the car at some point.
Old Apr 30, 2013 | 07:57 AM
timd38's Avatar
timd38
Enjoy!
To Mod progress and problems
