Fast Intake Next Mod or LS3 Upper End?
My personal best has been 12.298@118 which is decent for what I've done. I was running 17" DRs as well. The MPH indicates great HP compared to some others on the fast list with similar mods.
I am thinking of the Fast intake, but don't know much about it. If I go with that bolt on, do I need a different throttlebody? If I need both, that's a pretty expensive mod. I understand the LS3 and LS2 Fast intakes are significantly different.
I've read elsewhere that an LS3 intake and upper end will make a significant HP improvement. Those intakes are relatively easy to come by used. What's all involved with that?
Some of you who have gone this route, please chime in with recommendations....thanks.
Here is a pic of the slight difference in exhaust ports between LS2/3/7.
http://www.pfadtracing.com/photos/sh...php/photo/2361
Glad to see you sold the Camaro and put yourself back in a real car!
Or, if the budget allows... supercharger!!
See what's in our shop on Facebook! Customer Build Blogs!
www.pcmofnc.com
Performance Installs - Dyno Tuning - Mail Order Tuning & Sales
704-307-4227
I have a thread showing these mods overlaid on the dyno sheet. They build upon each other.
http://forums.corvetteforum.com/c6-t...ast-heads.html
As far as springs go, that depends on ramp rate and lift whether you can run a good single or need dual springs. You can specify wanting to run a single spring and the cam can be designed around that. Pushrods will also need to happen. The .080" wall Comp pushrods are more than adequate.
If you are going to boost the motor eventually you need to be honest with yourself on how much boost you are going to run. Less than 10-12 psi and you will be okay with stock castings and an LS9 head gasket. Over that amount and I would recommend an aftermarket casting with a thick deck for better gasket seal.
If you do the LS3 heads first, then when you get ready for a FAST, you'll buy the one for the LS3 and have the stock LS3 manifold left over.
If you do the FAST first, then when you get ready for the heads, the choice becomes sticking with the LS2 FAST and reworking your LS2 heads, or going with LS3 heads and buying a new FAST.
The less expensive direction is the LS3 heads first. The downtime is also shorter, moreso if you decide to port the LS3 heads.
All of the comments are super helpful, thanks...now find me a reasonably priced used Fast LSXR!
