LS2 Fuel Line
Old Jan 31, 2013 | 12:24 AM
Danspeed1's Avatar
Danspeed1
Default LS2 Fuel Line
I am jumping back into my engine build project on my C6. One of the parts I accidentally damaged was the braided fuel line leading from next to the power booster to the fuel rails. I did not have the proper tool to remove the fuel line and accidentally damaged it. Do I need to purchase a whole new line, or is the clip inside the line replaceable; if so what is the part number?
DG
Old Feb 1, 2013 | 06:45 PM
Danspeed1's Avatar
Danspeed1
Old Feb 2, 2013 | 09:06 AM
Kenny94945's Avatar
Kenny94945
Not knowing what is damaged on the line, you mention just a clip.
Caution - that line is under pressure - you may want to replace - to avoid a fuel explosion!
FWIW - Visit a local GM dealer to see if the clip is available separately or if it is a standard clip used on many GM cars. You could try the GM Parts house parts diagrams (or call them) link someone this forum. But again caution without knowing what is damaged.
Old Feb 3, 2013 | 12:10 AM
Red Sleeper's Avatar
Red Sleeper
Just to let you know that anybody that installed an Edelbrock E force supercharger had to replace the original one with a longer one and should have the stock one laying around. You might go on the Forced Injection forum and see if anybody would part with the old one.
To LS2 Fuel Line
