Need Advice on Headers for LS3
Old Feb 3, 2013 | 05:58 PM
Rathmullan's Avatar
Rathmullan
Default Need Advice on Headers for LS3
Sorry in advance if this is a repeat of an old thread but I searched and have not been able to find an answer.
I'm considering headers for my '12 GS w/NPP. My goal is to keep the system as quiet and emmission test friendly as possible.
If I use long tube headers, must I replace the stock catalytic converters? Must I also replace the X pipe?
Are "shorty headers" an options?
Thanks in advance.
Old Feb 3, 2013 | 06:53 PM
jon6.0's Avatar
jon6.0
All long tubes replace the stock cats. Even if you put cats in with long tubes, you are still illegal. I wouldn't waste your time with shorty headers. If you want to pick up an extra 10-15rwhp I would put some factory GM LS7 exhaust manifolds, cats, midpipe, and axleback on your car.
Old Feb 3, 2013 | 08:53 PM
Rathmullan's Avatar
Rathmullan
Thank you very much. Yes, I have read about this modification elsewhere and with your clarification about the long tubes not being street legal, it sounds like it is probably the best way for me to go. May, I ask you this? If I do the LS7 exhaust swap, is there nothing that I can salvage from my Grand Sport exhaust system? Not even the mufflers? I have the NPP system.
Thanks again!
Old Feb 3, 2013 | 09:00 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Thanks again!
Sure, with a little work to reduce the X pipe from a 3" to a 2 1/2" you can still use your stock over-the-axle pipes and mufflers.
Old Feb 3, 2013 | 09:28 PM
Rathmullan's Avatar
Rathmullan
Thank you. Now I am beginning to understand....I think. So the LS7 system uses 3" piping through to the mufflers vs. the 2.5" on the LS3. I might consider doing the work on the X pipe to downsize it to adapt to the LS3 2.5" exhaust (post X pipe) as long as I wouldn't leave any torque or horsepower on the table by doing such. Do you think that would be the case (i.e., I would give up some of the horsepower gain by constricting the pipe diameter to 2.5" post X pipe)?
Thank you once again!
Old Feb 3, 2013 | 09:35 PM
glenB's Avatar
glenB
Use the LS7 intermediate pipe and reduce it down by the axle. Back that far I really doubt you'll have any restrictions on the HP at moderate levels. As the exhaust gas cools it slows down so having the 3" to 2.5" will help keep the velocity up. If you decide to cam then you might want to reconsider keeping the stock over the axle stuff.
Old Feb 3, 2013 | 09:45 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I did an entire exhaust off a ZR1 (Z06 same except mufflers until 2011). Our Vette was not an NPP so I added the NPP in a box and quiet when I want and noisy when I want so you would have almost headers without worry about passing smog
Old Feb 4, 2013 | 12:00 AM
jon6.0's Avatar
jon6.0
Old Feb 4, 2013 | 01:12 AM
CandyRedDevil's Avatar
CandyRedDevil
Texas Speed 1 7/8 longtubes no cats and borlas sound like this......
Old Feb 4, 2013 | 07:24 PM
Bedouin's Avatar
Bedouin
I just went through this evaluation process & bought an entire LS7 sytem (w/ 8,000 orig mls) for my '12 GS dry-sump w/ NPP.
I wanted to keep my LS3 exhaust unmodified so I could go back to stock without any issue. I just planned to bring the LS3 mid-pipe & LS7 mide-pipe both into an exhaust shop & for $150 have them match the LS7 midpipe ends (with Walker 3" to 2.5" reducers) to the width/angle of the LS3 midpipe ends, so it would mate right up to my stock NPP's.
In the end I decided to install Pfadt 1-3/4" headers & cat'd midpipe into my 2.5" NPP's, CA smog laws be damned, & will sell this LS7 system. I was told the LS7 system only gives up @ 10 hp to headers, but the sound & extra 50 hp/tq with long-tube headers/tune was too enticing to resist. I also bought factory GM LS7 head gaskets & the only other item to buy would be 24" racetronix o2 extensions. I bought the 12" but used them in my Pfadt install.
To Need Advice on Headers for LS3
