Abs
Old Feb 4, 2013 | 12:09 PM
RareSS9596's Avatar
RareSS9596
Default Abs
I don't know if I am describing this problem correctly but it seems that under hard braking my abs comes on way too soon? Any ideas? Thanks.
Old Feb 4, 2013 | 01:10 PM
Homer3D's Avatar
Homer3D
How hard is hard braking? Sounds like ABS is doing exactly what it is intended to do.
Old Feb 4, 2013 | 01:16 PM
BEZ06's Avatar
BEZ06
Tires are what really stops the car.
What tires are you running?
Are your tires old/hard/smooth?
Is this on the street, or at track events?
Do you have stock brakes?
What brake pads are you running?
If you have a BBK and/or an aggressive pad, maybe you have too much brake for your tires.
Bob
Old Feb 4, 2013 | 02:39 PM
SG4206's Avatar
SG4206
I believe I am correct in saying that the ABS works when one of the tires slips during braking. It releases the brake pressure on the sliding tire.
So , I assume you are hitting the brakes on slippery pavement ,and or hard tires.
Old Feb 5, 2013 | 06:32 AM
RareSS9596's Avatar
RareSS9596
Nope. Just a hard stop. Not locking up the brakes. Dry pavement. brakes act as if i'm on ice.
Old Feb 5, 2013 | 10:18 AM
SG4206's Avatar
SG4206
I see you had a '07 , so you have driven corvette ABS before ; go to the Dealer service dept.
Old Feb 5, 2013 | 11:55 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
What brake pads are you using?
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
To Abs
