No key fob detected
Anyone have issues like this, even after replacing the battery?
http://forums.corvetteforum.com/c6-c...ement-diy.html
It's most likely that some electronics in the car is causing the interference. Be sure you don't have any cell phones plugged in inside the cabin, or any other strong electronic devices.
A slight possibility is a bad fob-detecting antenna. There are several in the car.
next is there interference with phone or charger or any other device that didnt come with the car.
third...
since you have a 2008... does your last digits of your vin end between these numbers? if yes then its possible you have a recall, see link posts #8..
85105302
85106987
http://forums.corvetteforum.com/c6-c...em-recall.html
Elmer made a checklist (click and open).. http://forums.corvetteforum.com/atta...-checklist.pdf
note: your fob does not need to be programmed if the 'slot trick' works. that means the car knows your fob so no programming required. if neither fob works in the glove slot, then yes maybe programming would help. keep in mind, if the fob's used to work and the glove slot wont recognise them, then reprogramming probably wont help because first step is to erase them from car, then add them back in. i wouldnt ever erase them unless you KNOW they are good fobs!!
questions
do you have 2 fobs? no, then buy another and risk progamming them. if the new one works but old one doesnt then its the old fob thats just bad!
you have 2 fobs and they both act badly and you replaced both batteries, i'd start checking to see what in the new car was added that has electronics that might be causing interference. anything and everything. including something you have on your person or have in the car. remember you said your new car, so what did the seller add that messed up interference?
do you have a recall for your 2008 per the link i sent? if your in the recall list, free fix!!
rcdlr replacement aint gonna be cheap nor easy, to figure out which went bad and then replace.
you can verify with a dealership that these are the ones and order and replace them if you wish. again, i'd leave that to the very last resort..
good luck
the antenna and its connector and wiring could in theory be bad, but again, last resort.
you in recall vin range? you have 2 fob? both (2) fobs act badly? any devices that came with your 'new 2008' that wasnt there during its manufacture?
*I do not have a number two fob, so I cannot test that.
*Car is not in the recall.
*no aftermarket items or devices in the slots.
*fob only works when placed near glovebox
*if I shut the car off, it will no longer recognize the fob
*it will lock the car with me in it, with the fob
you should purchase a 2nd fob.
go through the programming procedures for the new 2nd fob.
note that the car will think its the 3rd fob, because someone out there in the world has the 2nd fob (and can get in your car and start it anytime they want).
after programming your new fob, see if it works fine. if it does, then i would say your fob you have now is bad.
if both fobs only work in the slot, and since your sure that there is no interference, you have a bad receiver. in my opinion.
you cant prove you have a bad receiver until you verify that a new fob works badly also.
there is 4 antennas in the car and also a main receiver, that receiver is about $143 (item #1 in following link) and a dealership with the proper equipment has to change it because it has to be programmed and only they have the tech2 to do it. so your talking 2 hrs+ labor so almost $400 in that one part (not counting the 4 antenna which probably are good)
i want you to try this... try placing the fob on the dash right over the antenna , which is in dash, almost to the windshield, just to left of the speaker grill. if you get it there you are within 4 inches of that antenna and i'd think (unless it triangulates all 4 antenna) it should pick up the fob better. just a test for fun.
here is a link for a new fob (item #3)
http://store.gmpartshouse.com/parts/...agramCallOut=4
programming a 2nd fob.. steps 1-10 only..
http://forums.corvetteforum.com/c6-c...tructions.html
instructions that dealership will use to replace your receiver (your you said not in recall).. see #8..
well i read fine print on recall. i guess it doesnt matter your vin is outside recall range because the time has expired anyway. recall fine print said... What We Will Do: To correct this condition, your Chevrolet dealer will install a new module for the keyless access system. This service will be performed for you at no charge until October 31, 2008.
Also, I can unlock and lock my car from over 50 feet away, if that information is of any value.
well, my only fear is that the prior owner has tweeked/modified/added something that is causing interference. but, who know, things do fail so might be bad fob, bad antenna(s), bad receiver. actually i think receiver is probably a bad term, i think its more of a processor, but anyway..good luck
yea, you know thats something i have been wondering about. there are 4 'antenna'. one in the back end, to open hatch. 1 by each door, to open door. 1 in/under dash, i suspect that its the one for the starting of the car. but, i havent found a good answer yet. to start the car, does it use all 4 antenna or just the one in/under dash...
you find that out and we both have learned something
My guess is that something is interfering with the fob when it is in your pocket. This is common with cellphones, chargers and the like. Try a different pocket or a different placement....but get another fob as first order of business.
Your current problem is not programming related, so don't mess with that until you get another fob. Then you will want to use the long procedure to wipe all fobs and set the two that you will have as #1 and #2. Read the instructions carefully and don't jump in ***** nilly...or you could end up with no fobs that will work.
I think this is the case because my car is very good at discerning the position of my fob. With the top down, I can hold the fob an inch or so inside the window at the top of the door...and the car will start. If I move it just a couple of inches outside the door...literally three inches or so from where it was before, the car says no. It is extremely precise and seems to me that it must be using all the antennae in order to do this.
