Honest Opinion Please
So your choices are clear. More power or more filtration.
Independent testing shows K&N near the bottom of the list for good filtration and the stock Donaldson at the top. The difference in airflow is minimal, with the K&N being greater.
Clean filters allow more dirt through than dirty ones. Clean filters also allow more air through.
A greater total filtration surface area allows a higher airflow and a longer life.
You can do a simple two part test for filtration capabilities. First hold the filter up directly in front of the sun. You should not be able to see even the tiniest speck of light. Second, pour an ounce or two of water onto the filter. It should not immediately drain through the other side. Either or both failures indicate dirt will easily pass through.
The bottom line is, unless you have a real requirement for maximum power, good filtration is the better choice.
. Apply your common sense to this fact: The LS3 uses the same filter as the LS7, which is significantly larger, more powerful, and with a higher redline. Do you think your LS3 needs more air than your stock filter provides? The answer is NO. Plus you'd be sacrificing filtration, which is always a bad choice to make, even if there're a bit more HP at the very top of the rev range. And finally, any filter change, especially those crappy oiled ones, will eventually foul your MAF sensor, PLUS alter how it reads airflow (sometimes leading to lean conditions). Leave it alone man
On some LS3 and LS7 Corvettes, we've seen the same issue w/ low speed surge. To cure, please take a look at this component:
http://shop.callawaycars.com/Diffuse...-203682740.htm
I hope this helps -
I hope this helps -
While we sell very few of these diffuser kits, it does alleviate the surging at low speed as you have described. If we can be of further assistance, please feel free to contact us.
Without continuous maintenance of the filter eliment,
the K&N will allow truck loads of dirt and debris into your intake and the engine.
The filter oil is great for gumming up MAF sensors as well.
I stopped using K&N in the 90's because it was just too labor intensive trying to maintain a clean engine.
