Used Header Install
Feb 11, 2013 | 07:51 PM
Used Header Install
I am installing a used set of headers that I recently purchased on the forum. I have all the clamps/hardware as well as the o2 extensions. I do not have gaskets. Can i reuse the original gasket? If not, can anyone recommend a gasket? Thanks in advance.
Feb 11, 2013 | 07:57 PM
I had no problem reusing the factory exhaust gaskets
Feb 11, 2013 | 08:01 PM
Cruise-In VI Veteran
St. Jude Donor '12
Def. reuse the metal gaskets. They don't leak and can be re-used a bunch of times as long as you don't bend them up.
Feb 12, 2013 | 01:28 PM
In case you're looking for some good instruction or torque specs, Pfadt's site has a great install write up..
Feb 12, 2013 | 01:34 PM
Quote:
Originally Posted by
Bedouin
Thanks Bedouin!
We recommend the MLS (Multi Layer Steel) gaskets like the OEM and the Cometic ones we offer. So reusing the OEM ones will be a good solution for you.
Feb 14, 2013 | 06:12 PM
Thanks for the info. The write up on PFADT's site is excellent.
Feb 15, 2013 | 10:17 AM
the header install is real easy. knocked mine out in about 2 hours. you going catless?
Feb 15, 2013 | 11:26 AM
mriley1
yes i am going catless ... should i still use the rear o2 sensors?
Feb 15, 2013 | 11:34 AM
yes, i did. i bought the sensor extensions and zip tied everything up. i am no pro, and this was my first header install on anything ever but it was a breeze
Feb 15, 2013 | 11:36 AM
i didnt even have a lift. basic hand tools and jacking it up onto cinder blocks is the route i took. probably couldve got it done sooner if i had a lift and didnt have to crawl around on the ground
Feb 15, 2013 | 01:45 PM
Use the rears, but you may pop a check engine light. But that's simple enough to tune out.
