TPMS question for the computer know alls
Old Feb 16, 2013 | 08:17 PM
SuperchargedStroker's Avatar
SuperchargedStroker
Default TPMS question for the computer know alls
If my wheels and tires were replaced with another set, and the sensors not functioning, outside the annoying check system light, is there any effect.. Timing retard, anything weird?
Been driving it this way for a bit, wasnt in a rush to switch em to the right TPMS. I have newer wheels and tires. I swapped them out when I had a need to replace tires, but got a killer deal on wheel with tires, so I just swapped the whole set-up.
Any computer woes to go with that situation?
Old Feb 16, 2013 | 11:10 PM
ChevyDave's Avatar
ChevyDave
i havent had it happen , but i did research on it before. here seems to be a good topic and some good answers to your question..
http://forums.corvetteforum.com/c6-c...f-no-tpms.html
you will either be put into limp mode or not. other than that nothing harmfull.
Old Feb 17, 2013 | 12:40 AM
HOXXOH's Avatar
HOXXOH
No issues other than the light as long as the tires are close to the correct size or the correct front to rear relationship.
Old Feb 17, 2013 | 07:17 PM
azZ06Mike's Avatar
azZ06Mike
St. Jude Donor '11
Computer should adjust accordingly after a few revolutions
Old Feb 17, 2013 | 08:09 PM
cclive's Avatar
cclive
If you keep the old wheels with sensors near the car in the garage, you will be able to drive about 20 miles without the light coming on...then it will reset again when you return to the garage.
To TPMS question for the computer know alls
