missing power?
Old Feb 17, 2013 | 09:21 PM
SlowArse's Avatar
SlowArse
Default missing power?
Just got a 2010 coupe m6 with 23k on the clock. Took it to the strip today in Lexington Oklahoma. My best was a 12.93 at 114.82mph which seems very slow. Admittedly I could only manage a 2.2 60foot time.
Is 114mph slow for an ls3 car with b&b axle back? I'm worried. Track elevation 1100 feet engine temp 220
Old Feb 17, 2013 | 11:37 PM
SlowArse's Avatar
SlowArse
I was expecting to trap more like 116 or 117. Base coupe no options so no extra weight. I weigh 200 in clothes and a helmet. 1/3 tank of gas
Old Feb 18, 2013 | 04:11 PM
Seadawg's Avatar
Seadawg
You seem to be OK, based on your 60'. Meaning, I don't personally think anything is wrong with your vette, based on this info alone. There are too many things that could sway your mph in the 1/4.
For example, you could lose a couple mph in shifting, in spinning, riding the clutch a little, not full throttle all the time, etc.
What did you hit in the 1/8? It should say on your slip.
Old Feb 19, 2013 | 03:17 PM
85mcss's Avatar
85mcss
FWIW, I've only been down the track a hand full of times in my 23k 06 but my PB was a 12.92 @ 115 with a 2.2 60'....
Yours sounds about right.. I would think you should be a bit higher MPH and a few tenths faster being an LS3 but not by too much with that 60'
Old Feb 19, 2013 | 05:07 PM
Thomasmoto's Avatar
Thomasmoto
Yes, give us your 1/8th mile info.
Old Feb 19, 2013 | 05:09 PM
Thomasmoto's Avatar
Thomasmoto
With practice you should be able to get your 60 ft down to at least a 2.0.
Old Feb 19, 2013 | 08:37 PM
SlowArse's Avatar
SlowArse
Eight was 8.62 at 90.61mph
Old Feb 19, 2013 | 09:00 PM
HOXXOH's Avatar
HOXXOH
You'll be fine when you sort out the launch. My first pass with my bone stock A6 was 12.65 @ 113.26 on a 2.12 60'. When I finally got under a 2.0 60', I went down to 12.4's @ 116. Seat time will get you there.
Old Feb 19, 2013 | 09:55 PM
SlowArse's Avatar
SlowArse
Thanks sounds good
To missing power?
