Dry Sump
Old Feb 18, 2013 | 07:10 PM
timd38's Avatar
timd38
Default Dry Sump
Has any one installed one of these?
http://www.xplosiveperformance.com/D...A_p_3090.html#
Old Feb 18, 2013 | 07:53 PM
cb63's Avatar
cb63
I have that system installed on my car. I do not know how to post a link to the post I made about it. It was on 1/14/11 in the autocross and roadracing section
Old Feb 18, 2013 | 08:02 PM
timd38's Avatar
timd38
Would you buy it again? and what oil tank and pan did you use? ARE part numbers if possible.
Also, I am trying to find your post and noticed that you were at the Rolex 24. I was as well and had dinner on Friday night with a bunch of Corvette people I never met before.
http://forums.corvetteforum.com/auto...-pictures.html
Old Feb 18, 2013 | 08:38 PM
cb63's Avatar
cb63
I will look for part numbers when I get back home thursday night. It is a good system and has worked well for me
It's not cheap just for the parts as I listed in the post. The labor will be a good bit also unless you can do it yourself.
The only problem with anything in the system is this. The pulley drive that mounts on the belt tensioner is not a good design. The bearing it runs on is at the far rear of the assembly and the drive belt runs on the extreme other end of the assembly. The bearing cannot support the pull of the belt and it failed. My mechanic, Buddy Hendricks figured out a way to modify the pulley to where two bearings could be installed and so far that has worked.
Old Feb 18, 2013 | 08:43 PM
timd38's Avatar
timd38
Thank you very much for your help. Our cars appear to have a lot in common. Pfadt suspension, FAST intake etc. Thank you very much for your help!
To Dry Sump
