Pfadt Coilover & rear shock mount?
Feb 18, 2013 | 11:23 PM
St. Jude Donor '06-'09,'22,'25
Reason: Update
Feb 18, 2013 | 11:33 PM
looks like the very top ring of the "boa mounting system" if they are the featherlights?
Feb 19, 2013 | 06:24 AM
St. Jude Donor '08-'09 & '12, '14
Feb 20, 2013 | 08:30 PM
AHhhh, what happened to post #1 and what was the outcome/determination. Please PM if need be, inquiring minds would like to know.
Feb 21, 2013 | 05:40 AM
Thanks for responding, their CS is second to none.
Mar 7, 2013 | 06:04 AM
That sux, I'd try one of the online corvette bone yards
Mar 7, 2013 | 07:54 PM
Quote:
Originally Posted by
C6-CYa
Tell me about it! The problem trying to find it anywhere is that I can't find a part number. Pfadt saw my photos, you would think they would tell me that the new coilovers couldn't be installed :-(
Well, I found a complete shock with the mount for $30 each, it hurts, but what'cha gonna do?
http://www.corvetterecycling.com/product_p/10302877.htm
better than $120 dealer list and they are a vender here
Mar 8, 2013 | 05:28 AM
C6-CYa
Sweet, thanks Glen, I didn't even think of looking for used shocks with the mount! Can I assume that the mount can be removed? I haven't seen a factory shock and mount. Steve
Yes, they are removable
Mar 16, 2013 | 10:32 AM
Post photos of what you have. The Featherlights have the BOA top mount that bolts directly to the upper mount of the chassis. The rears need the plate that is attatched to the top of the shock. White dot to the front.
Just re-read you first post. If it's the rear plate you need, contact Marc at Vettenuts and I bet he will hook you up for a lot cheaper.
Mar 17, 2013 | 03:01 PM
C6-CYa
Thanks for the referral. I actually ended up fabricating my own mount from steel plate.
FYI, the original Pfadt's came with an aluminium mount with an integrated heim joint.
I know the old ones did, but I thought you said you ended up getting the new Featherlights.
Glad you got it resolved.
Mar 16, 2015 | 02:34 PM
Did you ever find the piece you needed?
I'm looking for stock mount plates as well
Mar 17, 2015 | 09:44 AM
c5wolf
Same coilovers and same noise here as well.....shock was broke?
