Under hood power sourse?
Old Feb 24, 2013 | 06:23 PM
Sayfoo's Avatar
Sayfoo
Default Under hood power sourse?
I want to pick up a switched (on when engine is running) 12v in the engine compartment. This will be a low draw--1/2 amp. Anyone know what fuse I could piggy back off of in the engine bay fuse box?
Old Feb 24, 2013 | 08:34 PM
CGZO6's Avatar
CGZO6
You could tap into the fuel pump relay.
Old Feb 24, 2013 | 09:52 PM
ChevyDave's Avatar
ChevyDave
is j-fuse slot #32 empty? it says in the manual it is.
Old Feb 24, 2013 | 10:11 PM
Sayfoo's Avatar
Sayfoo
Yes, that would solve the hot when running part, but how physically would I tap into the relay?
I wonder if the wire from the fuse box to the pump is accesable?
ChevyDave's Avatar
ChevyDave
actually the word they use in the manual is... BLANK (not empty)
Old Feb 24, 2013 | 10:18 PM
ChevyDave's Avatar
ChevyDave
not sure about actual term. add a fuse adapter (or FUSE TAP ) or something like that
like this...
for any fuse that is hot when engine is running like you want
To Under hood power sourse?
