Need help with seats
Old Feb 27, 2013 | 11:49 PM
acrc6's Avatar
acrc6
Default Need help with seats
I recently installed Corbeau A4's in my C6 1LT (no heated seats or memory). I purchased the sensors from Dan at VetteWorks and re-installed the bladder from the passenger seat. I was told by an associate from TPS Motorsports that if I zip-tie the bladder and put it under the seat, that would work.
After I hooked all those pieces up, I had to take out this little black box that the bladder seems to plug into.
Everything hooked up well and no airbag light. Passenger Airbag sensor says ON. I drove the car the other day and my airbag light seems to come on and off intermittenly and then eventually stays on with the Passenger Airbag sensor switching from ON to OFF.
What seems to fix it temporarily is when I unplug and the re-plug in the plug that goes into the little black box. But after awhile, it does the same thing I previously mentioned with the airbag light coming on again.
Any clue what could be causing this?
Any help would be appreciated.
