Using additives for ethanol
Old Mar 11, 2013 | 09:53 AM
ebmorse's Avatar
ebmorse
Cruising
Default Using additives for ethanol
Anyone had experience or thoughts about using additives to reduce problems with ethanol in gas? Example would be Bell Performance Ethanol Defense. What brands of gas have ethanol-free premium? They are hard to find in our area of western NC. Thanks! Mr. Ed
Old Mar 11, 2013 | 11:10 AM
gbrtng's Avatar
gbrtng
take a look: http://pure-gas.org/
You have more choices than I do here in south TX.
Old Mar 11, 2013 | 11:31 AM
mikeCsix's Avatar
mikeCsix
I receive a monthly publication called Motorcycle Consumer News. They don't accept advertisements which helps cut down on bias in their reporting and evaluations. They are researching an article on ethanol additives which is a very sensitive issue with motorcyclists as many bike sit in garages all winter long, mine included.
That aside, nobody I know is aware of any additives that really help mitigate the issues with ethanol and extended downtime. About 2 months of downtime is about max with ethanol laced fuel unless you can find pure gasoline.
Old Mar 11, 2013 | 12:07 PM
Bill Dearborn's Avatar
Bill Dearborn
NY State has had 10% Ethanol in all of its gasoline since 2005 when the MTBE additive was banned.
I see no issues with any GM engine using 10% ethanol sitting around for several months. My Z is driven on a somewhat reduced schedule during the winter and the last time I filled the tank was in early December. Engine still runs fine.
Most people in the north used to add dry gas to a tank of gas and running the engine to make sure it got throughout the fuel system before storing their cars for the winter. The dry gas absorbed any moisture and kept it in solution Vs letting it form water puddles in low spots in the fuel system. Don't need to do that anymore with Ethanol in the gas.
Bill
Old Mar 11, 2013 | 12:44 PM
truckplay's Avatar
truckplay
there are places in the midwest that are using e-15 possibly even e-20 and imports are having enough problems that warranties are being voided. Domestics do not have those issues. if you want to be safe use LUCAS ethanol fuel treatment. i use it on my small engines, mower, weed eater, boat, bikes and jet ski.
Old Mar 11, 2013 | 08:10 PM
1fastbob's Avatar
1fastbob
Bill
I agree and I have also never had ANY issue with E-10 in any of my cars, trucks, weed whacker, and lawn mowers. Only thing I have noticed that is negative is the slight reduction in the fuel economy department.
Old Mar 12, 2013 | 11:31 AM
turbotuner20v's Avatar
turbotuner20v
Lots of people run E85 w/o issue, I can't imagine E10 is making any difference in a modern car. Worst case it hurts fuel economy.
Old Mar 12, 2013 | 11:42 AM
Ferocious C6's Avatar
Ferocious C6
Oh really? Do tell more
Old Mar 12, 2013 | 11:54 AM
turbotuner20v
My car runs on E85, as well as many other older local cars. So far, I haven't seen any negative impact from the ethanol content.
It takes ~30% more e85 to equal the energy production of 91 octane though, so fuel economy is not good. On a gas blend that uses 10% ethanol, you may notice a small difference in fuel economy, but that would be it.
Old Mar 12, 2013 | 12:47 PM
Werks's Avatar
Werks
Same here, been running E85 with a tune in my '11 Z for the last 6 months or so with zero issues.
Old Mar 12, 2013 | 02:40 PM
Ferocious C6
And without a tune, too?
Old Mar 12, 2013 | 02:53 PM
turbotuner20v
it's making 915whp w/ a procharger, so yea, it has a tune
Old Mar 12, 2013 | 02:55 PM
Bedouin's Avatar
Bedouin
The ethanol in our California gas wreaks havoc on carburettors, & if left in a float bowl too long it forms gelatinous blobs & clogs jets, not to mention the o-ring degradation. All of my motorcycles get the carbs run dry before they're shut down. I'm told Stabil works well, however I keep the gasoline rotated out & haven't needed it yet.
Old Mar 12, 2013 | 03:49 PM
Ferocious C6
Perhaps that information would help the OP. Not everyone is running a supercharged/turbo/insane NA build, tuned for E85. And some people may be dumb enough to read your post and think they can just pour e85 into their stock corvette.
The engine doesn't care if you're running E85, as long as you're tuned for it. But you do have to plan your fuel system around it
Old Mar 12, 2013 | 04:43 PM
turbotuner20v
I would assume if he's in the tech section of a forum about his car asking about getting rid of the minimal standard ethanol content in his gas, he's not going to all of a sudden throw E85 in it.
Old Mar 12, 2013 | 04:59 PM
Ferocious C6
You say that, but someone asked about using nitrogen in their tires in this section. That in itself says something about the knowledge of these people.
Old Mar 13, 2013 | 10:10 PM
bookemdano's Avatar
bookemdano
I use regular Sta-Bil the red stuff it helps with the condensation that ethanol leaves in the fuel tank.
There is another additive from Sta-Bil called Marine Engine treatment it has a darker color it works really well drying up the e-85 ethanol fuel, if you let your car sitting around far some period of time using e-85 it will start building "condensation/water" build up in your tank, SOME TIMES IT WILL START THEN HESITATES AND SHUT OFF...
Old Mar 13, 2013 | 10:25 PM
saplumr's Avatar
saplumr
In the past I used stabil but couldn't find it for ethanol. Switched to Seafoam, it covers all the bases.
Old Mar 14, 2013 | 02:14 PM
Bill Dearborn
Getting gelatinous blobs and clogging of jets happens with any gas whether or not it has Ethanol in it. Stabil works for about 6 months and then has to be refreshed.
Bill
To Using additives for ethanol
