emissions error code help
Old Mar 22, 2013 | 09:40 AM
Abirli's Avatar
Abirli
Default emissions error code help
Hey CF,
in PA we have to have a safety and emissions test for inspection.
i passed the safety part but failed emissions with error codes P0121, P0158, P2272, P2273.
To fill you in i have the ls3 with z06 manifolds, Borla 3" x-pipe, and B&B 3" bullets. i also have the halltech mf103, and a ported TB.
for the o2 sensors, we de-loomed the factory ls3 sensors to stretch them to fit the z06 bungs.
the Tech said that it was unusual that the lean and rich codes would come up at the same time.
do you guys think i need a tune to clear it all up or new z06 o2 sensors or what?
thank you for any help
Old Mar 22, 2013 | 12:26 PM
irok's Avatar
irok
Originally Posted by Abirli
Hey CF,
po121 is indicating a problem with your TPS sensors in your TB and you say you have a ported TB.you may want to check that. try a stock TB for a start.po158 is indicating a problem with 02 sensor bank 2 sensor 2
Old Mar 23, 2013 | 07:47 AM
truckplay's Avatar
truckplay
check for burnt harness to the rear sensors. could you have dropped or banged the sensor during install or removal ?
po# 121 is the thottle, check to see if the blade is moving smoothly.
To emissions error code help
