A/C compressor not coming on?
Old Apr 13, 2013 | 06:36 PM
turbo87's Avatar
turbo87
Default A/C compressor not coming on?
My a/c compressor is not coming on, it has freon in when i attach gauges. What should be the voltage at the compressor?right now i have know voltage at compressor, the fuse and relay seem to be ok.What else should i look for? Thanks
Old Apr 13, 2013 | 06:42 PM
saplumr's Avatar
saplumr
Check continuity at high and low pressure switches during cycle..
Old Apr 13, 2013 | 06:44 PM
turbo87's Avatar
turbo87
I see one pressure switch it has 3 wires,that the only one?
Old Apr 13, 2013 | 06:54 PM
saplumr's Avatar
saplumr
I have never looked for them on my car but I would assume there are 2 switches. Low pressure switch on suction line (large line) and high pressure switch on liquid line (small line). Suction would be the most likely culprit,(if the malfuntion is a switch) if compressor cycles on immediately then shuts off it's a sign of low refrigerant.
Old Apr 13, 2013 | 06:58 PM
turbo87's Avatar
turbo87
It does not cycle at all. Does the digital control in the dash ever go bad? To make the conpressor not come on?
To A/C compressor not coming on?
