Can someone point me in the right direction for a Cold Air Intake for a 2009, C6, LS3. I have been looking at two models one that you oil the filter and the other you wash. Any thoughts?????
Callaway Honker or Variram
both are good, The Variram does block the radiator and so doesn't work as well for road racing (track) the Variram works better on the drag strip. costs are about the same
Thank You
Many good options out there. The LS3 factory piece is pretty good to begin with. You could start by cutting the shroud to allow cooler air into the filter area , and adding a beehive or similar piece to isolate the air filter from the engine compartment air . I used the oiled filters for years, I am currently using the Airaid synthetic non oiled filter, I like it a lot. Soap and water clean up . Good luck in your search .
