Coolant Gauge Issue/Question
Old Apr 24, 2013 | 11:39 AM
ALLEN007's Avatar
ALLEN007
Default Coolant Gauge Issue/Question
Here latley my "Check Coolant Level" words come on but level is fine. Also intermittently the analog gauge as well as digit readout for the coolant temp won't be working and then it kicks in and readout/temp is fine. Any ideas for me? Some kind of sensor? Thanks
Old Apr 24, 2013 | 11:56 AM
RicK T's Avatar
RicK T
Likely a bad temp sensor.
Check this info from ChevyDave then click on the link at the end for more info:
Originally Posted by ChevyDave
it measures a difference in temperature reading based on engine coolant temperature and engine speed to determine if the cooling system has a "LOW COOLANT" condition. The DIC message stays on for two ignition cycles
worded a different way... The "Check Coolant Level" message is triggered by an algorithm that compares the rise in coolant temperature over a given period of time.
if you have issues, and they dont go away, its possible thermostat replacement may fix it, or..
if it persists, i assume that the calculation can be recalibrated, money will fix anything
running through the search function, i did come across this.. temp sensor..
http://forums.corvetteforum.com/1578371022-post6.html
Old Apr 24, 2013 | 12:39 PM
ALLEN007's Avatar
ALLEN007
Would the sensor be something that would be easy to replace? Meaning, can I do it?
Old Apr 25, 2013 | 06:17 AM
ALLEN007's Avatar
ALLEN007
Ttt
Old Apr 26, 2013 | 03:35 PM
cclive's Avatar
cclive
Yes, easy...I don't remember where it is exactly but someone who knows will post...or you can search and will find pic. As Rick said, sensor is likely.
Old Apr 26, 2013 | 03:38 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Temp sensor is driver's side, behind alternator just in the #1 plug area.
Elmer
Old Apr 29, 2013 | 11:53 AM
ALLEN007's Avatar
ALLEN007
Elmer
Thank you, I'll try and find it.
To Coolant Gauge Issue/Question
