View Poll Results: Do Cold Air Intake Systems work???
Yes, there are significant performance gains!
16
30.77%
No, it's all hype, and has little, or no, performance value.
7
13.46%
The answer is somewhere in between.
29
55.77%
Voters: 52. You may not vote on this poll
Cai
Old Apr 26, 2013 | 10:08 AM
S'vette's Avatar
S'vette
Originally Posted by bud miller
i went with z06 box/bridge and an attack blue filter...very happy with that mod, and of course exhaust and tune.....
Whats the difference between the two intakes? I know the Z06 doesnt have that harmonic box on the side, does it change the intake note any? Thanks.
Old Apr 26, 2013 | 10:13 AM
S'vette's Avatar
S'vette
Originally Posted by haljensen
The stock setup is NOT drawing air before the radiator.
Most of the air reaching a stock C6 filter has been through the radiator and over, around and through the engine before it reaches the filter. The stock radiator shroud prevents fresh air from reaching the filter from the front of the car. Cut the shroud to allow fresh air into the filter and you will have gains.
and exactly what I did. ant say if I can feel any gains or if there really is or not but I was just hoping to lower the intake temps a few degrees.
Old Apr 26, 2013 | 11:31 AM
bud miller's Avatar
bud miller
s vette, yes the sound note is great..the attack blue is supposed to flow more air..
Old Apr 26, 2013 | 11:55 AM
Mike's LS3's Avatar
Mike's LS3
I think the OP should of added one more answer:
Do CAI's with a tune have significant gains? Answer: Yes.
Gains are not significant unless you tune the car. Any fuel metering change alone will only minimized your gains unless it is tuned for that mod.
Old Apr 26, 2013 | 12:17 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Well that's not necessarily true either.
Like I explained, the stock tune is VERY conservative in regards to heat and pulls timing very early as temps rise. If you feed the car cooler (as close to ambient as possible) air you will avoid this pulled timing and see huge increases if you were previously hitting the temps where timing begins to be pulled, which is something ludicrously low like 86 degrees.
Old Apr 26, 2013 | 12:30 PM
C7/Z06 Man's Avatar
C7/Z06 Man
Hey Bud, just curious; why is the fuel line out of alignment with the valve cover groove?
Old Apr 26, 2013 | 01:41 PM
HOXXOH's Avatar
HOXXOH
The easiest way to determine performance gains is at the dragstrip. SOTP and dyno sheets can't document or duplicate the information acquired from a timeslip.
I initially propped the shroud and it showed some reasonably decent gains. Then I switched to a Vararam and gained more. I don't believe there is more without altering the car's appearance.
Since the quickest bolt-ons on the performance list are using Vararams, it's pretty clear it is the power leader. If anything else was better, we'd all be switching to it.
Old Apr 26, 2013 | 02:01 PM
SK360's Avatar
SK360
You'll never convince me of that when the hard data says otherwise.
http://forums.corvetteforum.com/c6-t...ts-inside.html
lol
Old Apr 26, 2013 | 07:19 PM
TripleAstyle123's Avatar
TripleAstyle123
Originally Posted by pahlbfishn
More air flow=more DIRT sucked into engine. To each his own.
The engine is going to pull as much air into the intake as possible, thus this makes no sense at all. Cooler air provides more horsepower, so instead of pulling air from under the hood where it is very warm, pull it from your grille with a vararam to see increased perfomrmance using the same dirty air your stock intake sucks in.
Old Apr 27, 2013 | 12:48 AM
Mike's LS3's Avatar
Mike's LS3
I think that was my point. I agree, cooler IAT's will provide hp gains. The combination of a well designed CAI and a tune will maximize those gains by lowering the IAT's. It is not so much what you gain, but what you gain to loose. There are many factors in a custom tune that will help a CAI, i.e. MAF rescaling, reprogram PE values for WOT, lowering IAT threshold, etc. Again, anytime you change fuel metering you need to tune to maximize gains.
Old Apr 27, 2013 | 08:43 AM
FloydSummerOf68
I don't think that what I said was your point. You said "gains are not significant if you don't tune" and that's definitely not true if you're using a true CAI to avoid the loss of timing in the stock tune.
Old Apr 27, 2013 | 12:28 PM
Mike's LS3's Avatar
Mike's LS3
My actual quote was "Gains are not significant unless you tune the car"
1. True CAI + Tune = 25 - 35 rwhp.
2. True CAI and no tune = 8 - 12 rwhp.
3. Oem air intake - no hp gain.
Which scenario would you say is more significant hp gain?
All cars will benefit from cold IAT's!
We known the oem tune will pull timing with IAT's above 86*. But, that is not the only measurable timing that will be pulled in the oem tune.
1. Coolant temps above 213*.
2. Torque management
3. Knock recovery rate and limit.
4. False knock
What I am saying is a properly tuned engine with a CAI can alleviate horsepower robbing measures and make significant gains. IAT's is only one measure of hp being loss. You have to look at the whole picture.
Old Apr 27, 2013 | 12:46 PM
  #33
Mike's LS3's Avatar
Mike's LS3
lol
That supports my argument! A CAI alone will not make significant gains, a CAI and a tune will! Most hp gains will come from the tune.
Old Apr 27, 2013 | 03:58 PM
  #34
dennis50nj's Avatar
dennis50nj
all i know is i have the hard data, i have posted it many times but like anything else that works it falls on deaf ears for whatever reason or motive to bash a product, i had my car tuned and a 160 stat and cartek fan module, gained a .010 then months later the vararam was introduced, i bought it in Dec, i installed it drove the recommended 200 miles without stepping in to it hard, then took immediately to track, car ran .050 and 5 mph faster DA was within 10 ft, now thats not speculation, hearsay,or ********, just plain honest facts, now i set atop the bolt/ons list for years, gave LS1LT1 that very same magical vararam and he sits in 2nd with less bolt/ons and hit 127 mph with the vararam and of-course Cartek tuning, the list shows that vararam is #1 now in my view that is hard facts, proof, common sense, and no ********
Old Apr 28, 2013 | 07:54 PM
  #35
ParisTNDude's Avatar
ParisTNDude
I've had Vararam CAIs on my last 4 LS engined cars and they always performed better than others. I can say that from multiple drag racing and road course venues with other similarly low modded Corvettes, especially in Europe. When I won the trophies, some always asked why my car ran faster than theirs? I could only point to the Vararam since all other factors were relatively equal.
