I have a 2008 Z51, the dealer says my shocks are fine ( have bumper to bumper warranty) but my 98 Z28 has a more comfortable ride on Monroe shocks. I'm thinking Bilstein, which in their series of shocks would be the most "Comfortable" I'm a cruiser and don't plan on eating up any tires no time soon.
I too found the ride on our 2009 Z51 coupe to be quite harsh on the bombed-out roads of Illinois, even with Michelin tires. I installed base model factory shocks in the car and the ride is tremendously better, not quite as controlled of course but handling is still very good and much less floaty than F55 cars set on Tour.
If I ever go to stiffer shocks, my choices are the Bilstein HD or the Koni FSD. Both have their fans.
I was thinking Koni but........ not sure I want to spend that much on shocks right now, Thanx
There is a HUGE difference between an F body suspension and a 'Vette suspension. The springs/shocks are much heavier duty on the 'Vette.
I had a 2000 Formula Firebird, used it to tow my boat and had to change to air shocks because the boat would drop the rear bumper 4 inches or more when I hooked it up. Same boat towed behind the '05 Z51 'Vette didn't deflect the bumper 1/2 inch.
If you want a soft ride you'll have to find softer springs. Maybe do a change to coilovers where you can buy any rate spring/shock you want? Remember that the great handling that the 'Vette has will disappear with softer springs/shocks.
Is your car Z51 or base suspension?
Would you say that the improvement is more in the handling, or more in the softness of the ride?
Started out as base but I have the Z51 sways front and rear as well as the supercar tires. Also a thicker tunnel plate.
The car handles much better than when it's OEM configuration. Not track stiff but very solid as compared to the bouncy and lose OEM feel.
I have driven a OEM Z51 and did not like the harshness of ride. My present set up as describes is more complaint around town yet with the Pfadt street alinement handles very well considering street only car. Very predictable in the turns without the harshness.
I have upgraded the suspension on my previous two car also. A E46 M3 as well as a Grand Touring 350Z. Both where street only non DD cars too.
So much is personal taste for the street without the benefit of having lap times to compare.
The FSD's seem to do both for ride and handling but then I have other factors interfacing as I mentioned.
Thanks for the comments, still pondering between the Bilstein HD or the FSD....
I've had Bilstein Sports on other Corvettes and definitely don't want them on these roads.
choices , choices..... If you decide on the FSD I would certainly be interested in your opinion of them as I am going to be replacing mine and am on the fence between the two. I did not realize the FSD was so inexpensive (I did not want to say cheap) lol.
I really wasn't trying to compare the two cars. This is my first Corvette and thought that an expensive car like the corvette would have a more comfortable ride than a Camaro Z28. It just goes to show that you don't know what you don't know. lol
+1 for the Koni FSDs. Switched to them from stock shocks on my GS and the improvement in ride and handling (particularly on rough surfaces ) is significant, IMO. Excellent shock and expensive, but based on my experience, they are well worth the money.
Wait, wait, no one picked up on this? You towed a boat behind your '05 Z51??? Pics please, must be a sight to see....
so far i've read what i've liked about the Bilstein Sports for my Z51, but i haven't found much about the Pfadt shocks. anyone have experience with those?
Old picture. Towed to a local meet just to aggravate some of the local purists.
If you want to believe that softer shocks make a big difference on ride quality I can't change your mind. Spring rate is what makes the ride, put 100 pounds in the back of the 'Vette and the car doesn't drop at all, put 100 pounds in the back of your Malibu and the bumper will drop a couple of inches. Springs, not shocks.
