Hit rev limiter
Old May 7, 2013 | 11:25 AM
kmthor00's Avatar
kmthor00
Default Hit rev limiter
Yesterday driving home in my 12' GS w/ headers, off road pipe & NPP, I nailed it at about 65 mph, trans was in S, now I'm not sure if I bumped the paddle or what but this thing screamed up to red line hitting the limiter. At first I thought I blew the engine as it was so loud with the NPP, or thought I exploded a muffler. Either way the car obviously acted as designed, fuel shut off & spark pulled back or whatever it should be called. The car sputtered for a second or 2 & returned to normal driving, I should be just fine correct?
Thnaks, Ken
Old May 7, 2013 | 11:38 AM
Justasheet's Avatar
Justasheet
Thnaks, Ken
What rpm is your limiter set at?
Old May 7, 2013 | 11:40 AM
FloydSummerOf68's Avatar
FloydSummerOf68
Should be fine. I've done it more than once when it spins hard without getting traction from a roll.
Old May 7, 2013 | 11:51 AM
kmthor00's Avatar
kmthor00
Great question, I honestly am not sure what my tuner set it to? The dam thing spun up so fast I wouldn't have seen it.
Old May 7, 2013 | 12:07 PM
torquetube's Avatar
torquetube
That's what the limiter is for.
Old May 7, 2013 | 12:13 PM
Justasheet's Avatar
Justasheet
I've done it before and unless you notice something, you are fine. Thankfully, they put them on there for us.
Jeff
Old May 7, 2013 | 01:35 PM
pit-man's Avatar
pit-man
I've hit the limiter many times while tuning different tranny\TC's on my stroker motor. Not a problem in 4+ years of track and street driving.
Old May 7, 2013 | 03:15 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
No problem. I've hit the limiter many times too. It's there to prevent problems. Things come apart at too high rpm's.
Old May 7, 2013 | 03:55 PM
LEAVINU's Avatar
LEAVINU
Have hit it numerous times in my GF's 2010 GS (A6) and it's fine. Stupid paddle shifters are so slow to respond when using them and trying to get every rpm. Definitely on the list to "tune" once some headers and intake go on her car.
Old May 7, 2013 | 07:15 PM
Pfadt Racing's Avatar
Pfadt Racing
Should be fine
Old May 7, 2013 | 09:34 PM
Old Boot's Avatar
Old Boot
Isnt that how ya know its time to shift????VROOOMMM
Old May 8, 2013 | 08:11 AM
FloydSummerOf68
A tune will not decrease the delay between hitting the paddle and starting the shift; it will only decrease the time the actual shift takes once it starts.
The paddles will always be slow to react, unfortunately
Old May 8, 2013 | 10:57 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
That's the most important question. Hopefully, no problem.
Old May 8, 2013 | 01:47 PM
kmthor00's Avatar
kmthor00
I have a call out to my tuner but with only mods being Kooks headers & off road pipe I can't imagine the shift points have been adjusted or raised.
Thanks to all,
Old May 8, 2013 | 03:07 PM
blkbrd69's Avatar
blkbrd69
Not comletely true.
A very good transmission tune will make the paddles work quite well, and you wont have to do the shift and wait routine. Not something you can do with the normal tune software. Chuck COW and ECS are the only ones I have felt that seem right.
There is also some changes in shift firmware and trans. pressure settings between years.
IMHO some tuners raise the rev limit a bit much.
Old May 8, 2013 | 04:04 PM
CroOrange's Avatar
CroOrange
If the rev limit was left at the factory settings, it's fine. If it was jacked up, maybe not. You need to make sure if the rev limit has been modified or not, and it's setting if modified.
Old May 8, 2013 | 04:18 PM
dbratten's Avatar
dbratten
As you nailed it hard at 65 there's a good chance the trans dropped into 2nd gear which then redlines very quickly. Bouncing off the limiter is fairly common, especially in autox where you may not want to shift prior to an upcoming corner. So, no harm there.
Next time, use the paddles to downshift into 3rd and take off from there. You'll have much better control.
--Dan
To Hit rev limiter
Old May 8, 2013 | 04:28 PM
kmthor00's Avatar
kmthor00
--Dan
Thanks Dan, Certainly felt like that is what happened, now add in headers & open NPP exhaust, I thought I blew the exhaust off the back of the car! Scared the sh*%t outa me.
Old May 9, 2013 | 08:58 AM
FloydSummerOf68
Originally Posted by blkbrd69
Not comletely true.
Hm....I don't know about that. I don't think there is anything in the tune to do that. If there was a way to make the paddles remove the delay I would pay any amount to make that happen if it were a software change.
Old May 9, 2013 | 09:24 AM
LEAVINU's Avatar
LEAVINU
Haven't done it yet myself but know a handful of people here locally, ridden in their cars, and their trans tune made the shifts pop. No GTR or Ferrari speeds but definitely noticeable when compared to stock settings. I can hit the paddle at 6k and it will take it to almost rev limiter to actually shift; that's pathetic. These other guys can go right to the limiter and hit the paddle without hitting the limiter.
Don't know what's being changed but can confirm whatever it is works from my own eyes.
