New LS Timing Cover Alignment Tool! Check it out!
Old May 11, 2013 | 10:29 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Default New LS Timing Cover Alignment Tool! Check it out!
AlignIt Timing Cover/Crank Seal Alignment tool
Here is a simple but very effective tool to help you make easy work of installing your LS1-2-3-6-7-9 timing cover and seal.
The Alignit tool gets the timing cover centered perfectly with the crank and installs the seal in seconds!
Having the seal centered accurately with the crank minimizes the chance of seal leakage. Only $19.95
http://www.saccitycorvette.com/Timin...nmenttool.html
Update! We made a improvement to the AlignIt!
We will have to add a a few bucks to the cost. The New price
will be $26.95.
We will keep the $19.95 price through the Memorial weekend.
After that we will implement the new price.
Also if you purchased a AlignIt without the O-Ring and you would like a O-Ring installed at no charge just send it back to us.
Basically the O-Ring lets the AlignIt fit snugger in the cover holding it in place better.
One other thing, we are working on a Rear Main AlignIt tool.
Here is a video that shows how simple it is to use.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old May 14, 2013 | 01:52 PM
SacCityCorvette
Supporting Vendor
Inexpensive way to insure proper alignment of your LS timing cover. Also makes seal installation a breeze!
Old May 20, 2013 | 06:43 PM
SacCityCorvette
Supporting Vendor
We have them in stock!
Old May 21, 2013 | 02:34 PM
SacCityCorvette
Supporting Vendor
Cool Tool!
Old May 25, 2013 | 10:22 PM
SacCityCorvette
Supporting Vendor
Lets remember what this weekend is about!
Old May 27, 2013 | 06:44 AM
dagrump's Avatar
dagrump
Just ordered it. Great idea!
Old May 29, 2013 | 05:23 PM
SacCityCorvette
Supporting Vendor
Thank you for your business, dagrump!
To New LS Timing Cover Alignment Tool! Check it out!
