Service Charging System?
Old May 12, 2013 | 04:26 PM
Detoxx03's Avatar
Detoxx03
Default Service Charging System?
Anyone ever seen this pop up? I got in the car to take it for a Sunday cruise to the gym and as I was driving this popped up. Got to the gym and decided to adjust my shocks to has to crank the car to turn the front wheels so I could reach the adjusters and it cranked fine each time. The battery that is in it was there when I bought it December 2011 so not sure how long its been in there. I'll voltage once I leave but everything seemed fine especially since I took the car on a 60 mile round trip yesterday. Wonder if its battery or alternator. Thanks.
Old May 12, 2013 | 04:42 PM
Detoxx03's Avatar
Detoxx03
Made it home fine. Cranked with no issues. Volts hold between 13.8-14.1 with a low of 13.5 other than the 12.0 with just the acc on and nothing else.
Old May 12, 2013 | 04:58 PM
RicK T's Avatar
RicK T
Does the horn work? If not check the fuse in engine comp. If fuse is blown it "can cause" the Serv Charging System msg.
Old May 12, 2013 | 05:00 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
. Happened to me.
Old May 12, 2013 | 06:01 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
What spark plugs are you running in the Vette? A lot of people have reported issues with NGK plugs. I have always run them with no issues. Search and you can confirm for yourself. Maybe just a loose plug wire and getting some electrical feedback.
Old May 12, 2013 | 06:14 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Common problem when you get an underdrive pulley...but I doubt you have one. If you have one then just turn off code p0337 (from memory, need to double check that).
Plugs are the most common cause, ZR1 plugs seem to fit the bill vs. NGK's everyone uses. Another cause is a burned lug on the starter causing resistance.
Old May 12, 2013 | 06:36 PM
Detoxx03's Avatar
Detoxx03
Thanks for all of the insight. I don't have a underdrive pulley. I am running a 8 heat range NGK non projected tip plug. I'll do some searching around and mess with it tomorrow since I have to run out and take the family to dinner.
Old May 12, 2013 | 10:01 PM
cclive's Avatar
cclive
Bingo...NGK, known issue.
Old May 13, 2013 | 09:55 AM
JayplaySS2's Avatar
JayplaySS2
I have a thread about it- go with AC DELCO if your heat range is an option-
Old May 13, 2013 | 11:12 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
ZR1 LS9 .040 AC 41-104 = NGK heat range 6
Elmer
Old Jun 19, 2013 | 01:01 AM
Detoxx03's Avatar
Detoxx03
To update you guys. I bought a new battery for the car. Put it in and all is well.
To Service Charging System?
