Speedometer not working
Old May 19, 2013 | 09:22 PM
jpee's Avatar
jpee
Default Speedometer not working
My speedometer has always worked perfect.. however since I installed a FTI 2800 converter, it stays at 0 ONLY at the track when I leave the line at FULL THROTTLE... When I'm on the street its perfect ..
But at the track it will remain at 0 until I cross the finish line, then it will kick in and show the correct speed (app110 mph) after I let off the gas...
Any thoughts...??
Old May 19, 2013 | 10:17 PM
dennis50nj's Avatar
dennis50nj
Any thoughts...??
mine does the same, always had since the converter only on fast launches even on the street, i think it has to do with the tune changing the converter slippage numbers, im just guessing
Old May 19, 2013 | 10:24 PM
jpee's Avatar
jpee
Originally Posted by dennis50nj
mine does the same, always had since the converter only on fast launches even on the street, i think it has to do with the tune changing the converter slippage numbers, I'm just guessing
Not that I'm happy it's happening to you, but I'm AM happy it's nothing to worry about...
Old May 19, 2013 | 10:31 PM
Knowklew's Avatar
Knowklew
St. Jude Donor '13-'14
I've seen this in TBSS' with converters as well...Not a real problem.
To Speedometer not working
