Both fogs lights are not working. When I attempt to put them on the green light on the dash indicates they are working, but they are not. Seems odd that both would go out at the same time. I assume I am getting power to them due to the fact the the indicator on the dash is working. any suggestions would be appreciated!!
OK, now I'm confused!! I checked the fuse and relay- no problem. I have aftermarket lights, so I even replaced them with the ballasts. STILL NOT WORKING!!.
Any suggestions would be appreciated!.
First thing to check is the bulbs man. You have to get to them first. Check with a multimeter for power before buying new bulbs. Hopefully that's the extent of your issue . If no luck, tackle it as suggested above.
I installed an aftermarket HID kit and neither bulb came on, yet the indicated worked. Come to find out that the polarity is backwards from the factory. I had two little jumpers that came with the kit and repinned one side of the jumper, installed inline, and it solved my problem.
