Rear Suspension Collapse - HELP!
Looking through the suspension with the car raised, it looks like the leaf spring was touching the diff housing, but I'm thinking this is because of the upward bow caused by lifting both wheels in the air. Once it's on the ground, it's hard to see it, but it looks fine. I couldn't find any obvious cracks or breaks in the leaf, but there's gotta be something that's not allowing the car's weight to be supported.
Any ideas on what to check out next? I'm new to this forum, so I'm guessing I can't post pics until I reach a certain number of posts. I'll attach the pics of the ride height when I can. Thanks in advance.
pics are free; just get a host free place like photobucket, post them on there, then hit copy of each pic and put it in your thread.
Here's the old and new Tutorials for photobucket from our Help Forum:
http://forums.corvetteforum.com/help...es-thread.html
http://forums.corvetteforum.com/c1-a...irections.html
As for your problem, it almost has to be a broken spring as that is what supports the weight of the car.
Here is just one example, does yours look like this?
http://forums.corvetteforum.com/c6-t...ing-today.html
Yes, mine looks just like that now. I saw that post while searching, but I can't find any cracks anywhere. I did notice I have a leak from the rear diff and the center of the spring has this fluid residue on the center section. Perhaps this has somehow broken down the fiberglass resin/composite of the leaf spring??? Sounds like a reach, but maybe it's possible.
As you said, it has to be the spring... I can't think of anything else that would support the weight. I was able to get the numbers from the spring: left side is stamped EP-GF72 and the right side is stamped 22208992. I tried to search briefly but couldn't find anything with either of those numbers. I'll look more and see what I come up with.
http://s483.photobucket.com/user/cpa...e%20Suspension
hopefully that works
But you would probably want to go the full Z51 spec if changing.
I've already replaced the two rear shocks so I'm already committed to keeping the F55 system. It actually does its job quite nicely for a non-track car. It doesn't feel like a go-gart and you can dial in stiffness when you want it. And I didn't pay dealership costs for the replacement shocks, not even half that.
If I were building a play car with track time, I'd go coil overs, but for my daily driver, though quite spirited, I'm the limiting factor for performance, not the system.
Another thought: I know many have done what you are recommending, but the shock mounts weren't designed for the load of bearing the weight of the vehicle, much less the shock load of a coil over.
With the homework I've done, it seems my real troubles have stemmed from the diff leak and not the suspension system. Unless you consider the vulnerability of the leaf spring to be a fault. Which I actually do think sucks. But then again that's because I actually have to fix mine.
Thanks for the thoughts though; I've been everywhere on this trying to figure out what I want to do with it.
Thoughts?
No Diff leak and No Cutouts.Driver side
Passenger side:
Driver side w/ tape measure (26" to fender)
Passenger side w/ tapemeasure (26.5" to fender)
Thoughts?
Regarding the OP's problem, the differential fluid is basically a high quality oil, with some additives. I would be slightly surprised if the oil would cause his spring to fail.
But I've been wrong before, just ask my wife...
