When exposed to road grit and moisture, the combination will form a slurry similar to lapping compound - teflon will suffer under that condition alone.
Search on the forum will confirm that currently available "Teflon lined Quiet End Links" will not stay quiet for long.
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I've been here for over 10 years, and have had them on customer and shop cars for years. My suggestion is to hit them with a little dry graphite lube every other oil change and they are typically fine. Now we do not see snow and salt like the northern states do, but they have still went well over 50k miles with no issues.
I do appreciate your response and understand you have a product to sell.
I lurk at this form for many years before the '10 joined date. I joined because of used parts for my '05 from forum members.
A search will reveal many failed expensive teflon lined quiet end links.
Even OEM is under $25 each and have lasted 8 years. Moog's cost is $18+change, contact between ball joint/housing is steel on steel and comes with built in grease zerk to infuse fresh grease. Hard to beat at face value when comparing with some of these expensive rod end end links.
-Power Grid is basically a steel ball joint within aluminum body very similar to oem except it is adjustable.
-Rod End type are noisy.
-Quiet end link w/teflon lining will not last.
Anyone have experience with MOOG Part # K750136?
I never specify teflon in an application that is subjected to the type of deformation damage like that in end links. The surface area is too small. Teflon works best with large flat areas.
The steel ball in aluminum socket design has all the same problems, but it's cheaper to manufacture.
It's not unlike most parts that start their slow journey to self destruction the very day they're installed. The lifespan for me has been in the 30-40K mile range. The wife's Caddy is at 69K and not a hint of noise....yet. Smoother roads and conservative driving style makes the difference.
Thanks HOXXOH for your experienced engineering input.
Case in point, with additional adjustability, PowerGrid charges an arm and a leg for their similar to oem design.
What is your opinion in regards to the Moog replacement?
The Moog part is fine. It is built heavier than stock. It comes with grease fittings.
Thank you for your input sir.
Although my current endlinks are not yet having problem but they are 8 years old, just being proactive.
I prefer ball joint design, as it is simple yet effective, especially of the steel variety, just as tie rods on most oem setup. Even if it is the expensive all steel rod end type, it remains an consumable item.
As a matter of fact, I went ordered from Amazon, total $89.60 w/Free Shipping to my door. Thats about $30 less than oem from forum vendor with shipping and 1/4 the price from some expensive quiet endlinks out there.
I ordered ahead before the need is to prep the steel body of the Moog endlinks and refinish it with POR15 as to protect it from the salty environment I live in.
Over at Autocrossing/Roadracing Section, several knowledgeable member have subjected a variety of end links to the combined racing/real world test. Lots of knowledge sharing can be had in that Section - sort of remind me of LS1tech.
Several years ago, I had three almost identical cars (wife and two daughters) and they ate sway bar links. I replaced them with Moog parts that had grease fittings and the issues went away. Not a Corvette example, but a Moog example
