MGW Lower box
Old Jun 13, 2013 | 12:07 PM
One Kick's Avatar
One Kick
Default MGW Lower box
My 05 Z51 had never shifted very smoothly, trouble engaging gears, missing shifts etc. Last summer I installed a new MGW shifter hoping this would solve the problem and it did somewhat but still did not provide the performance I was expecting. Not too long ago they came out with a lower box which I installed last weekend and finally got the shifting I was looking for. So a recommendation from me if you are considering changing your shifter change the lower unit also, its well worth the extra dollars and effort.
Old Jun 14, 2013 | 09:56 AM
timd38's Avatar
timd38
I never had shifting issues, but I installed one a couple weeks ago nd it sure is nice!
Old Jun 14, 2013 | 03:49 PM
victorf's Avatar
victorf
Same here.
Some shifting problem associates with the ageing/deteriorated oem rubber mount or linkage off alignment.
Other than that, if problems are within the trans, no shifter or shifter box can correct it.
Old Jun 14, 2013 | 07:38 PM
DSOM's Avatar
DSOM
So you didn't buy a newer version shifter like George says is needed?
Old Jun 14, 2013 | 09:11 PM
garye's Avatar
garye
St. Jude Donor '12-'13-'14-'15, '21
I just ordered one , not sure why other than how wonderful everyone said it works. i'm not sure how it will be better than stock, guess I will find out soon
Old Jun 14, 2013 | 10:49 PM
C6-13thPilotCar's Avatar
C6-13thPilotCar
Install lower box you will not regret it. Big difference.
Old Jun 14, 2013 | 11:48 PM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
I hope that you ordered the lower box as well. It is well worth it.
I had an older model of the MGW shifter and it was better then stock for sure. But I always like to try the latest and greatest so I got he newest MGW shifter and the lower box and installed them myself a few weeks ago. It is even better than the older version with the new box.
Shifts very easily, precisely, and smooth.
Old Jun 15, 2013 | 01:21 AM
gp2race's Avatar
gp2race
St. Jude Donor '12
You will love the shorter throw....and yes more possitive input is needed.
Old Jun 15, 2013 | 05:59 AM
garye's Avatar
garye
I got the shifter and the lower box for the MGW, however I must say my OEM shifter isn't all that bad, once installed I'll post my thoughts.
Old Jun 15, 2013 | 02:28 PM
One Kick's Avatar
One Kick
Another benefit of changing that oem lower box out, other than smoother shifting is the additional heat shielding that comes with it, I have noticed a difference in tunnel heat since its install. I insulated quite a bit when I put the upper in but removing the lower provided more access for insulation.
Old Jun 15, 2013 | 04:19 PM
victorf's Avatar
victorf
^^^For all practical purpose, heat shielding is a different situation, with or without the MGW lower box. Although I have one also. Additional always helps, especially with DEI type aluminum over fiber insulation and adhesive lined. Dynamat in the kit is actually an sound insulator and the black foam type sheet is the insulation material.
Back in 2010, during my first install with the second generation MGW, I went ahead and installed addition DEI heat shields. In particular, under the radio bezel, over the thick black oem foam, directly under the oem cup holder base and removed the arm console, did the same underneath. DEI type are long lasting and effective heat insulation even when direct contact with an heat source.
Case in point:
Made shields for air intake over the hot coolant hose, battery and fuse box, purposely left top open so as not to trap heat:
Old Jun 19, 2013 | 10:57 AM
garye's Avatar
garye
are your heat socks around your plugs worthwhile, are you happy with them. Getting pfadt headers july 2nd, just wondering if it's a must have, should have or could have.
Old Jun 19, 2013 | 06:49 PM
victorf's Avatar
victorf
I never did one actual before and after on the spot thermo reading.
Since I bought them at a special 1/2 price offer and they don't add weight. So I said-what the heck everything needs a little help!
Old Jun 19, 2013 | 07:41 PM
wjnjr's Avatar
wjnjr
What valve covers and coil brackets are you using? Looks good.
Sorry, off topic. I like the new MGW shifter and box setup too!
Old Jun 19, 2013 | 07:48 PM
victorf's Avatar
victorf
Reworked OEM valve covers. Plugged all the original coil bracket bolt holes + a little elbow grease to smooth and mirror polished the surface.
Homemade coil relocation brackets:
Old Jun 19, 2013 | 08:28 PM
wjnjr's Avatar
wjnjr
VERY nice work!!
If you ever get an urge to make some more, let us know.
To MGW Lower box
