Service abs, active handling, traction control
Old Jun 20, 2013 | 11:16 AM
dennis50nj's Avatar
dennis50nj
Originally Posted by Ferocious C6
This is a combination of the three, which eliminates the steering column.
I scanned it with an innova 3150, it brought up a code for my right wheel sensor in the history.
So it is my right wheel sensor, which means I will be replacing my wheel hub.
Before you buy a hub, did you clear and see if it comes up again? clean the plug, maybe the tire tech unplugged it by accident
Old Jun 20, 2013 | 11:51 AM
Mr.Nubain's Avatar
Mr.Nubain
From: If you wanna live life on your own terms, you gotta be willing to crash and burn Florida
I hope this doesn't happen with my C6, I had that problem with my C5 and it wouldn't go away and it would go off on the highway and jolt the car while at high speeds. If I took off traction control everytime I drove the car it wouldn't send that jolt throughout the car. What a pain, it's another reason why I got rid of the C5.
Old Jun 20, 2013 | 06:24 PM
Bill Dearborn's Avatar
Bill Dearborn
Do some checking with a DVM to see if you have continuity from the car connector back to the EBCM, check both the car and hub sensor connectors for corrosion, dirt, loose connections (make and female pins don't fit together tightly), etc. A lot easier to do those first than screwing around replacing the hub which is a $150 part at a minimum and still having the problem.
Bill
Old Jun 24, 2013 | 01:27 AM
brewcitygymratt's Avatar
brewcitygymratt
St. Jude Donor '13
Originally Posted by brewcitygymratt
I just started getting the same codes last week. Did yours start right after putting on the 305's or did some time pass before the codes popped up? I do know if it isn't the tires it could be as simple or inexpensive as a bad tpms sensor. Worse case scenario is its your ebcm which is around $1300 if a stealership does the work.
Well I just installed new wheels and tires 18x9 and 18x10.5 with new sensors and for three days the service abs/traction/active handling has been gone.
Old Jun 24, 2016 | 11:11 AM
Bernie333's Avatar
Bernie333
1st Gear
I have 2001 Coupe and have started getting ABS/Traction Control warning lights. I clear them from the readout and the icon lights remain which I expected. However, this has been going on for a month and sometimes when I get in the car, there are no lights concerning this issue. Then while driving, they will come back off. I have even had them go off while I was driving. Sure sounds like an elelctrical connection.
WHERE DO I LOOK FIRST?
