Low washer fluid message on DIC
Old Jun 22, 2013 | 05:57 AM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
Default Low washer fluid message on DIC
Does anyone know or notice if the LWF Message that use to appear on the DIC is still current I have a '13 and have a line for blutooth & the # that shows up (i didn't have on my '07) wondering if the message was removed to make room for the BT entry?
My washer fluid went empty and didn't get a message
Old Jun 22, 2013 | 08:44 AM
timd38's Avatar
timd38
The owners manual is you friend. If it doesn't tell you than it doesn't happen.
Old Jun 22, 2013 | 12:52 PM
cclive's Avatar
cclive
Page 5-51 of your owners manual says that the DIC will display a "CHECK WASHER FLUID" message.
Old Jun 22, 2013 | 04:20 PM
Rob 99's Avatar
Rob 99
Thanks guys, i did initially look in the manual but on pages
10-31 32
What threw me for a loop was the washer stopped spraying without a message i then checked it saw it was low and filled with a complete new gallon,(didn't think it would take the whole gal) some other vehicles iv owned never take the complete gal and you aways have a little in the bottle for a year or so
So the weird thing was it wasn't pumping no spray or pump sound i pulled & checked all related fuses they were all good, so i left it alone figuring i would need to make a trip to the dealer,then the other day i tried and it worked my thought was maybe it sucked some air in the hose's although if it was that low the message should have came on which brought me to my original question.
Something I'll have to watch to see maybe if it's a bad or weak pump motor
Thanks again Rob
To Low washer fluid message on DIC
