Power window switch replace
Old Jun 24, 2013 | 01:23 PM
dandeeceesix's Avatar
dandeeceesix
2nd Gear
Default Power window switch replace
Sorry if this has been addressed before. 2005 C6 Coupe. I have determined that the passenger window switch is faulty. Window operates fine with drivers side switch and does index when door opened and closed. Question...do I have to remove the entire door panel to replace this switch. Or, can the switch be removed by itself in its bezel.
Old Jun 24, 2013 | 07:55 PM
ColtaBilly's Avatar
ColtaBilly
Old Jun 24, 2013 | 11:13 PM
debo's Avatar
debo
No you do not have to remove complete door panel, great illustration listed above by "ColtaBilly".
Old Jun 25, 2013 | 06:47 AM
ColtaBilly's Avatar
ColtaBilly
Old Jun 25, 2013 | 04:21 PM
dandeeceesix
2nd Gear
Thanks for the quick response. Have a switch on the way so wish me luck.
Old Aug 10, 2019 | 06:40 PM
Scout05's Avatar
Scout05
Default Passenger power window switch corroded
I replaced the passenger side power window switch and disassembled the original one. The contacts on SW1-1, SW1-2, and SW3 all show signs of corrosion after cleaning. The contact on SW2 if half missing. J1 also shows some corrosion, especially around pin 1. It’s clear to me now why this switch failed. It’s just worn out. It was probably helped along the road to failure by getting wet. The new switch, ACDelco D1991F, GM 20794871, works great.
Old Aug 10, 2019 | 11:57 PM
wjnjr's Avatar
wjnjr
Great post, thanks for sharing.
To Power window switch replace
