ok, so i am confused.
I measured for push rods today. I measured both intake and exhaust on every cylinder, all of them at TDC when i measured. Each side seems to vary by alot.
I measured them to have a .075 preload, and used the adjustable comp cams push rod checker.
Here are my results:
Intake is left side/exhaust right side
#1-7.4/7.4
#2-7.41/7.42
#3-7.33/7.36
#4-7.41/7.41
#5-7.32/7.38
#6-7.41/7.41
#7-7.33/7.37
#8-7.41/7.41
is it normal for the driver side and passanger side to be so far off from each other?
And after looking at this, is there one set length that i can buy that will work for all of them? If so, what am i ordering?
hi mate not sure what engine you working on ,if you dont have adjustable rockers and your trying to set preload which i presume your doing , couple of things you can do wind your rocker down untill you feel all freeplay dissipear then from there you give it a full turn on the nut give or take a quarter turn if the rocker dosnt tighten at that you need to space it up or muck around and buy a pushrod to suit , obviously if you have valve seat recession on various valves this could take bit of time usually the ex valves that pound out ,the inlets dont give much trouble in that regard ,PM me if you like sometimes its hard to explain on paper good luck
It's an LS2. I swapped the whole top end. So now I have:
AFR 230V2 Heads, they have been slighlty milled (but dont know the CC, either 70 or 71)
Brian Tooley Racing lifters
Aruns Stage 3 "Jam Cam""
I used a piston stop, went one way, back the other way, measured to the middle, to be TDC
I am using stock rockers with trunion upgrade.
I was adding preload into the math, not preloading each one as i went.
-I measured off of 0 lash,
-counted each turn on the Comp Cams adjustable pushrod checker as .050
-then added the .075 preload
- then added the 6.8 of the pushrod checker when completely closed.
That is how I came up with these numbers.
Its the variance from 7.32 to 7.42 that worries me, because that seems to me to be very far apart from each other.
Almost the whole driver side was 7.3x and the passenger side was all 7.4x
There are several ways to achieve this.....here is one of the more weekend warrior methods.
make sure your on the base circle
using a know length pushrod tighten to zero lash (rocker becomes stable)
Take your torque wrench that is set to 22lb-ft and torque the 8mm bolt
Count the number of turns it takes to acheive 22lb-ft....1 full turn is worth .047"
Adjust the pushrod length accordingly for the desired preload
If you are totally confident your measuring is correct ; the .100 length differance has got to be in head deck thickness or rocker stud base height. What else can change the length? A test would be to shim the short side studs and see if the length comes out equal.
Reason: additioal info
Not sure how your numbering them in your post (firing order/actual cylinder numbers or just counting down the banks). But I readlly feel your over thinkin this, measure # 1 & 2 (opposing banks) take the average and go with that. The preload will take the "error" out of the average.
The difference your seeing is in your measuring method. Again, preload is your friend, you want to set your preload in a "safe" zone. Meaning, if there is a little discrepancy from cylinder to cylinder length, let the preload takes care of this. Example; 0.100" of lifter travel shoot for 0.050" of preload, that way if there is a little variance in length its no big deal.
To double check yourself.......put you adjustable pushrod in but shorten it so you know it will not contact the rocker, then torque the rocker arm down to 22lb-ft. Now begin to lengthen your pushrod till it is snug against the rocker(snug = can not spin the pushrod because its seated against the lift and rocker). Now loosen the rocker and remove the pushrod. Measure the pushrod and add your desired preload to the measurement. This method works because of the spring in the lifter keeps the plunger "pumped up" when the engine is not running.
I thought preload was around .040, am I remembering wrong ? I don't doubt that at all
This is exactly how I did it, and well, the motor runs! Worst part was the pushrods I needed were an inbetween size so I wound up with more preload then I probably need. At least with the morel lifers their is a lot of room for preload, don't know about the LS2's or LS7's
