C6 a6 transmission cooler install
Old Jun 30, 2013 | 11:18 AM
07ArcticVette's Avatar
07ArcticVette
Default C6 a6 transmission cooler install
I'm about to install a transmission cooler on my car. Just put a stall in it and need to find out the size of the fittings for the lines front he transmission to the radiator. It's a 2007 z51 a6. With hard research I can't find anything on the right connectors.
Old Jul 1, 2013 | 12:19 AM
Redrocket1045's Avatar
Redrocket1045
This worked for me.
2 - Summit 220649 6AN to 1/2" NPT threads
2 - Summit 220687 6AN 90 degree end swivel
2 - Summit 220690 6AN hose end straight
1 - Summit 230606 stainless steel braided hose - 6 ft.
1 - Dorman 800-605 fitting (available at your local parts house) ( 2 if you bypass the radiator)
1 pkg 12055 from Pure Choice Motorsports - you will use only 1 fitting if you run your cooler in series
1 - Russell 640830 M16 x 1.5 to -6AN Flare fittting
1 - B&M 80278 mounting kit
2 - 1 1/8 x7/8" grommets - Lowes ( you'll need to make 2 holes in the side of your shroud for your cooler lines). I used my dremel tool for this.
If you’re going to bypass the factory radiator – you will need another Russell 640830 fitting and another Dorman 800-605 fitting.
At first - I used a B&M Super Cooler 70266 and ran the lines in series. I wanted lower temperatures so I ended up bypassing the radiator all together.
These parts will allow you to connect to your factory lines without any cutting, splicing or using worm type clamps. Stainless braided hose is a PIA to work with but you just have to be patient. You could use regular A/T pressure rated line if you decide not to use braided lines.
Good Luck.
Old Jul 1, 2013 | 12:22 AM
Gering's Avatar
Gering
Tolero Apto Victum
Redrocket1045: Thanks for the info.
Old Jul 1, 2013 | 03:54 PM
TKOGTO's Avatar
TKOGTO
Originally Posted by Redrocket1045
This worked for me.
Good Luck.
Where did you put the cooler?
I have the B&M Hi-Tek A/T Cooler with the 9 1/2" fan mounted in the front right wheel well, plumbed in series with a DeWitt's rad and although temps dropped nicely upon install, they have increased recently to the point where they are higher now than before the B&M.
Old Jul 1, 2013 | 04:13 PM
jpee's Avatar
jpee
Just curious, what type of cooler are you using,, the reason I ask is I had been using a "Finned Aluminum" cooler in my 96 when I had it, & I hit a piece of truck tire on the highway it broke the cooler...
I went to the local auto parts store, and NEEDED a COOLER NOW as I was going to race the following day...
They only had one type of cooler it was a "STACKED PLATE" type so I go it and hooked it up in place of the old one.. and with NO other changes my trans ran 15 - 20 deg cooler under ALL conditions !!
Since then (1998) the only type of trans cooler I'll buy is a Stacked Plate Type !!
For what its worth !!
Old Jul 1, 2013 | 04:16 PM
TKOGTO's Avatar
TKOGTO
jpee - mounted where?
Old Jul 1, 2013 | 04:23 PM
jpee's Avatar
jpee
Right on the AC Condenser...I'll give Cartek a call, but I'm pretty sure thats where they put it when they did the converter...
Old Jul 2, 2013 | 03:19 PM
Redrocket1045
I have a 20,000 BTU stacked plate B&M cooler mounted in front of the A/C condenser.
Old Jul 2, 2013 | 03:44 PM
TKOGTO's Avatar
TKOGTO
I have my Setrab 625 EOC in front of the condenser so not sufficient room for a tranny cooler as well. Do you have a separate EOC?
You mentioned you wanted lower temps so you took the trans flow out of the rad. I have seen this debated. I went with thru the rad but will likely take it out once I relocated the B&M. How uch of a drop did you see removing the rad?
Old Jul 3, 2013 | 11:36 AM
Redrocket1045
I have a Dewitts radiator dual fan setup w/o the EOC. I have bypassed the A/T oil cooler in the radiator and the highest temps I've seen in 100 degree weather in city driving was 183 degrees. Highway temps average 160. I also have a 3200 stall.
Old Jul 3, 2013 | 11:42 AM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
I have a B&M transmission cooler and it's mounted in the passenger side front bumper opening. Works well, really got my temps down on the track.
Old Jul 3, 2013 | 11:52 AM
TKOGTO's Avatar
TKOGTO
In front of the condenser or did you remove the fog light?
Old Jul 3, 2013 | 12:38 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
And do you still use the radiator tranny cooler?
If so, which one does the fluid go through first?
Thnx.
Old Jul 3, 2013 | 12:47 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
This...
http://forums.corvetteforum.com/c6-f...er-update.html
Old Jul 4, 2013 | 05:46 PM
07ArcticVette
Thanks for all the helpful info has any just tryed to cut the hose on one of the lines going to the radiator. Also trying to find what line is the supply and return to the radiator the top or bottom.
Old Jul 4, 2013 | 06:45 PM
ironhorse583's Avatar
ironhorse583
the top line is return..dont cut the line..order the necessary connectors..
1 pkg 12055 from Pure Choice Motorsports - plugs into the radiator.
Dorman 800-605 fitting - attaches to radiator hose after removing from radiator
Russell 640830 M16 x 1.5 to -6AN Flare fittting - connects to the dorman fitting to allow the connection of the 6 an hose and fittings..
this way it is easily reversible and looks better...
all credit for fittings goes to Redrocket1045...thanks...
Old Jul 4, 2013 | 09:51 PM
HOXXOH's Avatar
HOXXOH
I simply disconnected the lines from the radiator, pushed a 3/8 hose over the ends, and double hose clamped it in place. Then again it's only been that way for 2 years and 30K miles, so maybe that's not the best approach. I keep the clips in the glovebox in case I need to revert to stock in a hurry.
To C6 a6 transmission cooler install
Old Jul 4, 2013 | 10:05 PM
jpee's Avatar
jpee
Just as a side note..I have a Stacked Plate cooler that is hooked up AFTER the fluid runs through the radiator, then it goes to the aftermarket cooler.. It does NOT have a fan, and in traffic, if my fluid goes over 190 I put the car in Neutral whenever I come to a stop..& that seems to help...
Just a thought for those of you who do not have a fan on your cooler...
Old Jul 4, 2013 | 10:20 PM
dennis50nj's Avatar
dennis50nj
same thing for 6 years, i double clamped the cooler end but just slide the rubber hose over the bevel on the line i think i put the clips back on the radiatori used an 12x12 hayden stacked plate dead center and the vararam still fits
Old Jul 4, 2013 | 10:26 PM
jpee's Avatar
jpee
I agree with using the "Stacked Plate" type... I found it keeps my trans fluid 20+ deg cooler than the finned type!!
