Bought a flooder, having a few electrical issues
I brought it home and got it in the air and found... no water in rear end...no water in tranny...pulled the oil plug and less than a quart of pure water came out then clean oil...
I pulled the spark plugs, no water came out, but a couple plugs showed signs of water.. I blew out all the cylinders and did get a little water coming out of the cylinders so I sprayed wd40 down all cylinders, let soak then cranked engine over..
I changed the oil and spark plugs and fired up the engine.. It took three attempts to get it started. After it ran for a few minutes it smoothed out and sounded good.
The next day, I took it for a drive and the check engine light came on.. the only issue I had was the cooling fan was not coming on..Everything else worked...I was so happy that I was driving this totaled out flooder one day after I bought it..
Today, I ran into a problem, my doors wont open, windows don't work, door locks not working.. They all quit working at the same time, so I feel like the problem is a bad connection somewhere. Any ideas anyone?
Fingers crossed you it's an easy fix, but this is the risk you take buying a flooder.
I hope it is not a can bus problem--if it is then oh boy.
Go ahead and buy a complete wiring manual for the model/trim of the car--you are going to need it.
Once electricity starts going through the wires again.....
remember the car may be dry--but the wiring harness isnt--even if that part of the harness didnt even see water. You have wicking and condensation problems to look out for.
Good luck!
I hope ya bought it real cheap....ya might make it back as a parts car.
I don't know how water got in the engine, it was either running and ingested it or it leaked in somehow.
I've already driven the car the day after I bought it.
It's far from a parts car, I have driven flood cars my whole life and never had any issues after they are properly serviced..
I got it cheap enough to be able to fix a few problems and not worry about it..
I came in here asking a question about an electrical issue, why would you be worried my wheel bearings or how much I payed for the car and then tell me I basically bought a parts car?
From my experience, most people that are afraid of flood cars have never owned one and don't have a clue about them..only repeating the horror stories they have read on the internet from people that don't know what they are buying or how to repair them..
Luckily, the price difference in price can be offset by the lack of potential problems, the clear carfax, and the fact that you don't have to worry about a flood vehicle.
I'd start with pulling the trouble codes (maybe see if someone has a tech II or a good code reader that can pull the codes from the BCM).
Also, like one poster above mentioned; make sure you pull every fuse and relay from the fuse block on the passenger floorboard (after taking a picture or making a diagram so you can remember what goes where of course
) and check for water damage there.You may have a problem with the fob system and not with the door locks at all.
I wish you the best of luck; these cars can probably give even the most experienced with flooders a pretty big headache.
Getting the codes pulled at autozone would certainly be a great starting point. If that doesn't get you anywhere, you could pay a dealer to pull all of them for you.
All of this hinges on you being able to get the car ignition to the "on" position by holding the bottom of the start button for a few seconds.
As for the price, you can buy a light flooded car like this one for less than half of the book value.
