Aftermarket Diff Cooler on Z06 Differential
The stocker relies on the trans fluid to keep cool, I've done a few C6Z trans/diff into C5 conversions, but often times remove the aft cover and ditch the pump on the C6Z diff
So if you road course, the diff cooler is a great idea. If you don't, it's not really needed.
BTW the diff fill and drain are an odd metric size that is impossible to find as an adaptor for the temp sensor. If you want a temp sensor, first, use an oil temp gauge which goes up to 300 degrees, then, buy a magnetic diff plug from a forum vendor like Ecklers, drill out the center and tap it for the 1/4" pipe thread that the sensor is (double check that measurement on the sensor, that's from memory).
Frankly 20 minutes is about all brake pads..or you...are going to want to do anyway most likely!
I do HIGHLY recommend a trans temp and diff temp sensor. I use one gauge in my pod for both, with the inputs switched via a double throw toggle switch mounted on the A pillar next to the gauge. Unlike the diff, the tranny drain or fill is a common size and the adaptors that come with the electric gauge will work fine. The factory z51 trans cooler does a great job, never rising above 240 or so. Same with the factory z51 oil cooler.
Two buddies didn't have a trans temp gauge or cooler in their C5 Z's and both cooked their transmissions on a hot day at Sebring. The got the "hot trans temp" warning on the Dic but it was too late - the syncro rings cook and then your trans won't shift worth a darn ever again, you need a rebuild.
Good luck on the road course...next mod should be R rated tires. And of course brake fluid swapped before every event. R tires are NIGHT and DAY. I won't ever bother running street tires again, it's like ice skating in sneakers. Just no fun.
In the above pictures, I think pic #2 will be least effective of the two. I would really like to know how pic #1 is working out. The alternative to these options may be to go with the T-1 version for the C-5 Z's, the problem there is losing one of the rear brake ducts unless I can fit the heat exchanger into the rear diffuser, removing the reverse lights and installing screens.
The track we run at out here (The Ridge Motorsports park, it can be googled) has 16 turns so on a hot day the diff is probably getting pretty warm, a cooler will help give balance to the situation.
I like the suggestion of adding a differential temp sensor to help keep tabs on what is going on back there.
I'm not on R-Compounds yet, those create another set of problems I'm not ready to deal with yet, like better brakes and oil starvation issues so i'll ice skate in sneakers for awhile yet. LOL.
If I was in your shoes, knowing what I know from a few years of doing this, I would just install a diff gauge and keep my eye on it and loop the pump for now. Since you have stock 3.42 gears you might not need a cooler.
And I would buy some R rated tires! It is SO MUCH more fun and you aren't burning up your expensive street tires.
Trust me you won't be disappointed. You don't need new brake pads for R tires. Your stock brake pads will pull your fillings out when you give them something sticky to work with.
Below 200 is very likely unattainable. Even in 55* with 2 days experience my tranny was at 210*. Now with your same DeWitts, 25 days and a B&M cooler with a fan, I average 250*. On days with the ambient in the 90's, I have to back off @ 268 twelve to fifteen minutes in. IMHO, 230 is not bad at all. Sure 215 or so would be great but that's unrealistic on the track no matter what tire you're running.
That said, coolers for the diff and trans are virtually a necessity for regularly tracked cars. Good luck.
I've been trying to find part numbers for the Z- coolers online at GMPartsHouse but can't find any pictures or references other than to the "axle-cooler" options for the various differential options. Anyone have an idea where I might find part numbers?
Hoping not to duplicate that again...
Normal temps get up to about 280F on the road course and I hear the cooler will drop 30F or more. Hope that helps.
