The Z06 rear spring is stiffer than your base spring, at 782 lb-in versus 657 lb-in. This will create more oversteer just by itself. Adding a Z06 rear spring would give you a pretty poor handling setup unless you are trying for a pure drift car.
But the springs and sways are independent. You don't need to change one if you change the other.
In one sense, that's correct.
But in the C6 sometimes you have different spring rates front and rear, that are compensated for with different sway bar stiffness. For example, the Z51 rear spring is actually softer than base, but the Z51 rear sway bar is much thicker. And the Z51 front spring is much stiffer but the Z51 front sway bar is only moderately stiffer.
I'm not sure how the relationships are on the Z06, but mixing parts from different suspension setups must be done with a lot of research and knowledge. The Z06 also has different wheels/tires from the base car, to complicate things a bit more.
Too many relative parts to consider. I vote coil overs or D/R.
