525 Cam
Old Jul 8, 2013 | 05:59 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
Default 525 Cam
Does anyone have the full specs on the GM ASA Cam. It is what comes in the new LS3 525 motor.
I need opening closing degrees on the cam, that is what I am referring to as full specs, not just the max lift.
Old Jul 9, 2013 | 11:14 AM
Zip Corvettes
Nobody has any specs on this?
Old Jul 9, 2013 | 12:56 PM
PPCFlyer's Avatar
PPCFlyer
http://bit.ly/1a8OZAE
Old Jul 9, 2013 | 01:22 PM
PRE-Z06's Avatar
PRE-Z06
PART NUMBER 12480110
ASA CAM
107 INTAKE CENTERLINE 110 LDA
1.7 ROCKER RATIO
Lift:
@Cam @Valve
EXHAUST: 0.309 0.523
INTAKE: 0.309 0.523
Cam Timing@0.004-inch Tappet Lift:
Open Close Adv. Duration
EXHAUST: 79 BBDC 40 ATDC 299
INTAKE: 32 BTDC 73 ABDC 285
Cam Timing@0.050-inch Tappet Lift:
Open Close Duration
EXHAUST: 48 BBDC 7 ATDC 235
INTAKE: 3 BTDC 41 ABDC 224
Old Jul 9, 2013 | 08:34 PM
Zip Corvettes
Originally Posted by PPCFlyer
That cool, but I was not looking to purchase one, but the entire cam card.
Old Jul 9, 2013 | 08:35 PM
Zip Corvettes
ASA CAM
1.7 ROCKER RATIO
Lift:
@Cam @Valve
INTAKE: 0.309 0.523
Open Close Duration
Thanks,
I had found it earlier right after I posted but I apreciate it. It has changed part numbers now, but it is still the same cam.
To 525 Cam
